Old 12-04-2004, 03:32 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
2 Turbo's on SL Motor?!?!?!
ok i just got done reading the FAQ sticky and i read the link about swapping a TT. i am new to the whole 3000gt world so someone inform me.
so that was a list of parts to do a complete TT swap to TT motor specs??? both motors, the SL and the TT have the same compression ratios? if the SL motor has a higher compression, wouldnt slapping 2 turbo's on a the high compression engine of the SL lead you to running very low boost or blowing the motor? someone explain the compression ratios of the 2 engines to me. are they the same?
ZedEx Crew Member #4
Old 12-04-2004, 05:40 AM
GritMaster GritMaster is offline
Compresion on the SL motor is 10:1 the VR-4(TT) has a 8:1 Compression
So You're limited to lower boost on a TT SL motor... think it was like 8 or something... someone just said.
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 12-04-2004, 10:02 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 2 Turbo's on SL Motor?!?!?!
There is a guy on 3si who runs 10psi on a 10:1 motor on pump gas. He uses a light amount of alcohol injection. If you want to run higher boost on a 10:1 you need more fuel, ie larger injectors. Being I havent looked at the FAQ I dont know how much info is there about the swap. If you want a ton more info, check out the FWD Forced Iduction section on 3si. You can probably spend hours reading threads about people who have or are going to be performing swaps or doing conversions.
Old 12-04-2004, 08:21 PM
Z Cars Fanatic
ok thats what i thought...
the FAQ section didnt mention anything about compression or boost. i figure with the higher compression of the n/a you would want to run water/alky injection to keep the intake air temp down, so you can run any moderate boost. ill check out that site but before i do i have one last question.
to lower the compression on the SL motor, the only thing you need to change is the 10:1 pistons to the 8:1 pistons???
Old 12-04-2004, 08:23 PM
Stealthee's Avatar
Basically yeah, but changing the pistons out is not a simple job. You basically have to tear down the whole motor to change them.
Old 12-04-2004, 10:23 PM
Z Cars Fanatic
well of course....thats with any car. i was just asking because i read the FAQ and it just sent me to a site where it explains everything you need to turn your SL into a TT. btu it didnt talk about compression or pistons or anything...im not new to the whole swapping TT engines and stuff. i am about to cross that path in my z32. thanks though...
Old 12-05-2004, 02:47 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Z32??? did you bore out your 300zx?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-05-2004, 02:57 AM
Z32 = 300zx
Old 12-05-2004, 04:58 AM
Z Cars Fanatic
Re: Re: 2 Turbo's on SL Motor?!?!?!
no...why?
yeah gritmaster said it...z32 = 90-96 300zx
Old 12-05-2004, 06:30 AM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
The 32 might make one think that its 3.2 liters I guess.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-05-2004, 06:38 AM
Z Cars Fanatic
oooooooooooooooooooooooooooooooooo................ ....i see, now. i was trying to figure out what the hell he was talking about. now it makes sense...
Old 12-05-2004, 03:07 PM
Linebckr49's Avatar
thanks for clearing that up...sorta. I'm still a bit confused on terminology/logic: how does 'Z32' correspond to the 90-96 300ZX?? i guess i need to read up on my history of the Z car.
93 3000GT base
Old 12-05-2004, 03:11 PM
They have different designations for the different cars heh. the 350Z is a z33. and a z31 is the older 300zx from the 80's
Old 12-05-2004, 03:24 PM
Linebckr49's Avatar
thanks. ya i kinda see the pattern. not sure where it comes from, but i guess as long as one can tell what generation of the Z car it corresponds to, its all good.
93 3000GT base
