Old 12-03-2004, 10:42 PM
uncutnick3kgt uncutnick3kgt is offline
Send a message via AIM to uncutnick3kgt
question about manifolds....
hey this may be a dumb question but i wanna know .... will the first gen manifolds from a vr4 fit on a 2nd gen sl.... or did they change from the years...
Old 12-03-2004, 11:28 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: question about manifolds....
Are you doing a TT swap?? If not then you cant use TT mani's on a NA.
Old 12-04-2004, 03:20 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
first gen manifolds will work, and as far as i know the only difference is the o2 pipes and downpipe. But to be safe I would recoment going all first gen or all second gen if you are doing a TT conversion. But it doesnt matter what year the car that is getting the turbos is.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-04-2004, 03:31 AM
GritMaster GritMaster is offline
Be careful though, You don't want any dangers to your manifold.
Sorry couldn't resist
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 12-04-2004, 09:57 AM
Stealthee's Avatar
LOL when it said "danger to the manifold" it was talking about intake manifold, in case you didnt know.
Old 12-04-2004, 01:04 PM
Yes, because he somehow blew the welds in the intake manifold. Im wondering how much boost it would take to blow up an intake manifold.
Old 12-05-2004, 02:31 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
ya, a little confused here. are we talking about INTAKE manifold, or EXHAUST manifoldS??? the TT intake manifold doesn't have the VICS, thus there are pros and cons with that. but the exhaust manifolds are made specifically for turbos, obviously. so if you have turbos (TT conversion) then it would most likely work.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-05-2004, 03:50 PM
the original question was about the stock exhaust manifolds, after my answer it was all fast and furious references.
Old 12-05-2004, 07:44 PM
yes my orginal question was about exhaust but i let them go .... ty for the help
