Old 12-03-2004, 08:09 PM
lakini lakini is offline
Send a message via AIM to lakini
changing clutch, how hard? 3-cyl metro
I was told today, that I don't have any adjustment left in my clutch.
The guy said I need a new clutch plate. My clutch lets out real high.
How much in parts, and how tough of a job for a limited skills mechanic?
thanks
Old 12-04-2004, 12:29 AM
SeanMurphy's Avatar
SeanMurphy SeanMurphy is offline
Re: changing clutch, how hard? 3-cyl metro
You have to drop the front sway bar, and remove the front axles from the transmission. remove the bolts mating the tranny to the engine, pull it away, and unbolt the pressure plate and clutch disk. you'll want to replace the pressure plate, clutch disk, and throwout bearing all at once to ensure you don't have to do it again. I did it with the help of a haynes manual in my back yard using nothing but hand tools, jack stands. and a friend to help me lower the tranny out of the way safely.
I got the parts at a local Chev dealer, they had the best price, and a chev dealer gives you 1 year warranty on parts, even if you install them yourself.
All I'd done prior to this was change oil and watch other people repair cars. It's not THAT hard, but plan on having the car laid up for a couple days. Additionnally, you'll want a clutch alignment tool to make sure the disk goes in straight. I borrowed one from a local Canadian Tire store for a refunded deposit of $40.
02 Chevrolet Tracker 4WD
Old 02-14-2005, 02:53 PM
chembrad chembrad is offline
How many bolts and nuts mating the tranaxle to the engine?
I pulled off 4 but it still won't come away from the engine. I must have missed one as something is holding it up.
'05 Dodge Grand Caravan 105k miles
'94 Geo Metro 1.0L 5spd 185k miles... at least I can fix it!
Old 02-14-2005, 08:11 PM
There was a thin plate at the lower passenger side of the transaxle that was held on by two 10 mm bolts. I had to remove this "flywheel view plate" in order to pull the transaxle case off.
