Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 12-03-2004, 07:42 PM
leadslinger leadslinger is offline
2001 2.7 idle problem??
I own a 2001 4x4 with a 2.7 and auto trans. My problem is when I come to a stop my tach drops down to 700 and my idle is smooth, if I sit for 20 or so second at a light my tach drops to 600 and the truck developes a shake or rough idle, has anyone else experienced this? Does anyone know what to do to correct it? My local dealer says this is normal for the 2.7.
Old 12-03-2004, 07:44 PM
lifetrddeath lifetrddeath is offline
Send a message via AIM to lifetrddeath Send a message via Yahoo to lifetrddeath
Re: 2001 2.7 idle problem??
I have the '00 2.7 and the idle does suck sometimes. hell every once in awhile the idle jumps higher and makes the truck want to move.
Old 12-03-2004, 11:36 PM
Shredhead Shredhead is offline
isn't the engine idol completely controled by the computer, I know that you used to be able to control it when toyota used a carberator but I think since they came out with injectors the idol was pre programed in the computer, the only thing I can think of that would screw up the idol is maybe a bad sencor some where?
Old 12-04-2004, 02:24 PM
OBATDDSD OBATDDSD is offline
Check for the easiest things. Vacuum leaks. Dirty maf sensor. Maf sensor especially if have a preoiled airfilter such as a k&n.
Old 12-04-2004, 02:34 PM
Thanks, OBATDDSD, I'll check your suggestions.Would a dirty maf sensor throw a code, or only throw a code if it wasn't functioning? Second question, how would you recommend cleaning it?
Old 12-04-2004, 10:24 PM
On my 95 it there was no check engine light. On my friends he had a check engine light. Strange huh... Maf sensor cleaner in a spray can at Kragens or whatever auto store nearby. It appears to be a slight build up of burnt on crud. Dont clean while hot or engine running.
