Old 12-03-2004, 06:24 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Winisd Help
hey guys, well currently, im trying to build a box for my 12 alpine type R, im TRYING to make a..
1.5 cu.ft box tuned to 30hz, but before any building begins, is this what im supposed to be seeing? is this correct? are there any errors anyone can point out? any help would be great, thanks
40hz
35hz
30hz
28hz
port
port and box size
Old 12-03-2004, 07:14 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Winisd Help
All looks fine, but those box dimensions only give you a 1.5cf sealed box, they do NOT take into account the port. When you add in the port it will be larger than that.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 12-03-2004, 07:18 PM
Re: Winisd Help
thanks sr20, so how would i fix this? find out the ports displacement then add it to the overall displacement of the box?
Old 12-03-2004, 07:23 PM
sr20de4evr's Avatar
Re: Winisd Help
yep
and remember, with dimensions like that you're obviously doing a slot port, so if it snakes through the enclosure you're going to have to find out exactly how much space the port takes up, including turns and wood. You can't just say 1.5*14*35.4/1728 = .43cf and add that, because once you add in those turns and the extra wood you have in there for the port walls, it's going to be larger than that.
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-03-2004, 08:21 PM
Re: Winisd Help
alrite thx sr20, im going to be building as soon as i finish the plans for it, first time building a box, any tips/hints?
Old 12-03-2004, 09:48 PM
sr20de4evr's Avatar
Re: Winisd Help
hmm....make straight cuts and use glue
oh, and caulk the joints on the inside after you have it built
other than that....I can't think of anything
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-06-2004, 10:27 AM
threedd97's Avatar
threedd97 threedd97 is offline
Send a message via ICQ to threedd97 Send a message via AIM to threedd97
Re: Winisd Help
So that's the program I should be using when planning a box? Anything I should know or is it mostly self-explanatory? Eh, I'll get it and ask questions later if I run into any problems .
UNOFFICAL AUDIO BRAND RATINGS
My life is composed of the worst luck known to man.
Disclaimer: My knowledge of car audio is questionable, but it usually sounds great to me.
'98 Grand Prix GT 4Dr
'06 XXX 12"
Possibly a Cadence ZRS-10
Pioneer DEH-5500MP
Old 12-07-2004, 12:04 AM
Re: Re: Winisd Help
it'll be confuzing when u first start, just hit us up here and we'll try to help you
on another note, sr20 i jsut finished the plans for my box, the total size is 2cu.ft the port is about .5cuft i did a bunch of calculations and made all the measurements already, gunna go buy wood, and pick up a circular saw then im set
and after that...... its time for me to build a fiberglass kick haha, any tips? i bought everything already, and i practiced by putting a cloth over a 6.5 speaker spacer.. ontop of a few sticks of wood.. nailed it to a piece of wood, and started by putting resin all over it, now its like a small 6.5 speaker box, but i haven't put any fiberglass and its hardending already, i didn't have any fiberglass sheets or anything so i just let it sit -_-
Old 12-07-2004, 12:15 AM
sr20de4evr's Avatar
Re: Re: Re: Winisd Help
Nice, just take your time on the box and double check every measurement. The first box I made had 1 wall that was about a quarter inch too long and stuck out, the second one had maybe a 1/16" lip on the bottom where the front face sat too far back, and from then on they're pretty good. If you're carpetting it then it doesn't matter anyway, because all of those will be covered up.
As for FG, I can't help ya, never tried my hand at it. I want to eventually, but it will probably be after college unfortunately.
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-07-2004, 11:19 AM
Re: Re: Re: Re: Winisd Help
ah i c, winter break is coming, hopefully i have time to do both projects soon, my cdts are coming this week, and i dont have a place to putmy tweeter, i might just need to hang it somewhere before i build my kicks
Old 12-12-2004, 07:32 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
those Q-forms are pretty good for most Hondas .... takes a lot of work out of it
