Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-03-2004, 06:02 PM
InSumNiaK InSumNiaK is offline
95 Integra ABS light comes on
Ive got a 95 integra and my ABS light comes on when I restart the car after
it has been running and will stay on. My ABS does not seem to be working at
all.
But on a cold start, everything is fine, the ABS light is off and the ABS work great.
Any idea what may be the problem or things I can try to fix this ?
I already added some brake fluid, but that doesn't seem to work.
Old 12-04-2004, 06:39 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
go to autozone or somewhere and have them pull the code...ill bet its a wheel speed sensor... they arent to hard to replace you just need to know which one.......
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 12-04-2004, 06:54 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
My friend has been running with his ABS lights on for 4 + years. Pull the ABS code as you would with a CEL, but, focus on the abs light instead of the CEL. here is a diagram.
code - problem - other parts that may be involved. **** denotes no other problems involved
1 - Pump motor over run - pressure switch
12 - pump motor circuit problem - motor relay, motor fuse, unit fuse
13 - high pressure leakage - solenoid
14 - Pressure switch - ****
18 - gas leakage - ****
21 - Parking switch problem - Brake fluid level switch. Brake light?
31 - front right wheel pulsers - ****
32 - Front left wheel pulsars - ****
34 - rear right and left wheel pulsars - ****
312 - you have different diameter tires
41 - speed sensor front right wheel - ****
42 speed sensor front left wheel - ****
44 - speed sensor rear right wheel - ****
48 - speed sensor rear left wheel - ****
5 - speed sensors rear rear right and left wheel - modulator
54 - speed sensors rear right wheel - modulator
58 - speed sensors rear left wheel - modulator
6 - fail safe relay (its open or shorted) - front or rear fail safe relay
61 - fail safe relay (its open or shorted) - front safe relay
64 - fail safe relay (its open or shorted) - rear safe relay
71 - open solenoid related problem front right wheel - ABS B1 fuse front fail safe relay
72 - open solenoid related problem front left wheel - ABS B1 fuse front fail safe relay
74 - open solenoid related problem rear right and left wheel - rear fail safe relay
81 - problem with ABS control unit - Bad ABS unit
82 - problem with ABS control unit - Bad ABS unit
84 -problem with ABS control unit - Bad ABS unit
any of the electrical or sensor problems are easily fixed.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
