Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 12-03-2004, 03:28 PM
holleytiger's Avatar
holleytiger holleytiger is offline
Send a message via AIM to holleytiger
94 jgc oil pressure sensor problem
hey buddies i have a 94 jgc laredo with 5.2l v8 and my oil press. ggauge on the dashboard suddenly stopped working and now only sometimes works. When it does work it only goes up to normal level right after starting up and the goes down to nothing and stays there. Its been doing this for some time and i aint losing oil and iwas wondering if anyone could tell me where this sensor is located so i can change it. Thanks.
Old 12-05-2004, 03:37 AM
Cam7 Cam7 is offline
The sensor on the 5.2 is located on back of the engine behind the intake manifold more towards the passenger side. It has a 2 wire terminal on top of the sensor. White wire is sensor signal, Light Blue is sensor ground.
Old 12-05-2004, 02:06 PM
Wink
thanks buddy i'll try that
Old 12-06-2004, 12:10 AM
ByronP ByronP is offline
Before you drive it too much you may want to make sure that it's really the gauge or sending unit that's not working. Mine acted just as you described. Unfortunately the gauge was working fine it was the oil pump that was crapping out. Good luck. I hope it's something simple. The oil pump is a PITA to change.
ByronP
93 ZJ w/V8, BB and UC springs, 31" MTZs, ProComp MX6, FM50, DynoMax Cat, OME SD40, Electric fan conversion
Old 12-06-2004, 07:43 PM
Well thanks. The gauge has been reading like that for about a month now. If the oil pump is bad in it would it have kept running this long. Also is there anyway to check it. Thanks buddy>
