Old 12-03-2004, 02:00 PM
faulk82 faulk82 is offline
92 Lumina
I Hope Someone May Have A Solution To My Problem. I Have A 92 Lumina Eurosport With A Couple Of Issues. After Starting In The Morning And Traveling Down The Road And Then Coming To A Stop, It Won't Go Forward. The Rpm's Rise But The Trans Won't Engage. After A Seconds, It Seems Like An Eternity, It Will Finally Go Into Gear And There Isn't Much Of A Problem, Until It Sits Cold For About 4 Hours And It Does It Again. I Had The Trans Fluid And Filter Changed, But It Still Happens. The Mechanic Said There Wasn't Any Metal Or Anything In The Old Fluid That Would Indicate A Problem. Also, When The Car Is Warmed Up And I Check The Fluid, It Seems To Be A Little Foamy. Can Anyone Help. I Want To Give This Car To My Son To Use, But Can't See Spending Major Bucks For A New/rebuilt Tranny. Thanks!
Old 12-03-2004, 05:39 PM
Kooterskkar Kooterskkar is offline
Send a message via AIM to Kooterskkar
See if it helps to put it in a different gear setting. WHen it does that push the shifter into 2 or 1 even and see if it kicks into gear then. If it does then it may be your shift cable is stretched.
Old 12-04-2004, 10:52 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 92 Lumina
If the fluid is foamy, it may be overfull on fluid. That will cause the car to not shift. I would guess that since it acts up when cold, that it's a sticking shift solenoid or sticking valve body if it's not an electronic shifted trans.
