Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-03-2004, 09:16 AM
riff22 riff22 is offline
alternator problem??
in my 95 talon tsi the dash lights flicker on and off like the oil, battery, coolent lights. i alson know that my headlights dim and the heater slows down when i let of the gas. i checked the alternator by starting the car and taking the neg. terminal off the battery and the car didnt stall. so the alternator still works. i know that most cars have a regulator that tells the alternator how much juice to pump out. is there one on these cars? and if so where? and is there a way to check it?
thanks
tyler
Old 12-03-2004, 09:49 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: alternator problem??
Your alternator might still be bad. You really need to have a load test done on the charging system. Autozone/Advanced will do these test for free. Might want to try that.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-03-2004, 08:39 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
On newer alternators, most have the voltage regulators built in.....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
