soild red light
ecu is throwing a solid red light i think that its code zero which is faulity ECU .....when i start it up it will run fine then when i take it to like 3 grand the check engine light turns on and the ecu light turns on and the motor will cut out at 3 grand i can drive it with the light on but i can rev past 3 grand it looses ALL power
you just think i should try and find a new computer or is there something i can check to fix the problem i have tried to reset the ecu about 4 times and still the same problem Anyone have an idea?? thanks for the help -Chris- |
Re: soild red light
check your grounds. had something similiar happen after we did a swap. it turned out to be a loose ground. if you check and all seems good then i would check the ecu.
"hi! my name is Lady, and i'm a HONDA-holic" ..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose! ![]() *~ I <3 the G Ride ~*~ I <3 OLD SKooL |
Re: soild red light
checked the grounds and everythings good i hear a tick everytime it happens when the check engine light comes on for down by the fuse box you think it could be an main relay going bad
Anyone have an other suggestions Thanks |
how would i tell that my main relay is bad and where is it located i kno its under the dash but i cant find it
Anyone have help? i think it might be causing the problem above^^ i can here it ticking everytime the check engine light one..... ANYONE? |
Re: soild red light
Its located behind the drivers side kick panel. The location and how to test it are both in helms
http://www.binghamtonlife.com/manual/2gsm/default.htm This does not sound like a main relay problem.
Re: soild red light
i tried a different ecu and a different dizzy and still has the same problem anyone have any other ideas of what it is im going to check the main relay today
i have no idea what it is..... |
