Old 12-03-2004, 07:30 AM
kllrclown kllrclown is offline
Question 2000 Taurus electrical problem...
This is the deal:
I seem to have an electrical problem when driving this car. When I push the power window buttons the headlights dim!! Also when I am driving on the highway, the headlights will dim and the speedometer "sweeps" down and then builds back up to the speed I was cruising at. Any suggestions?? Any info would be helpful!!!
Larry.
Old 12-03-2004, 10:08 AM
joe92k1500's Avatar
joe92k1500 joe92k1500 is offline
Re: 2000 Taurus electrical problem...
I would point toward a bad alternator. It sound like it is not putting out the correct voltage. But make sure to check your belt, clean and tighten the battery cables, and make sure the battery can hold a charge. These can all cause problems also. If i remember right Autozone can bench test the battery and alternator.
Old 12-03-2004, 01:42 PM
Re: Re: 2000 Taurus electrical problem...
Also when starting the car it sometimes hesitates....and makes a high pitched "squeal"...before it starts up. Could this be alternator related?
Old 12-03-2004, 02:51 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
thats my guess too.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-03-2004, 08:19 PM
joe92k1500's Avatar
The squeal could be alternator related, or the belt could be wearing down. If the belt has not been changed in a while, go ahead and change it with a good one when changing the alternator. I has to come off anyway. Gatorback is a good belt.
