Old 12-03-2004, 06:03 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
broken bov?
i have a hks ssq, and a few weeks ago, i was in 4th gear and accelerated a bit, hit like 10psi and heared BOOM and had no throttle....came to a stop and the car stalled....found out that my bov blew off the UICP somehow and smacked the hood (and i made sure prior to that, that it was definitely seated and tightened)...anyway, i noticed tonight when i took my bov off, and move it from side to side, there is a small rattle in it...like if i move it to one side, it sounds like something is hitting something, and so on....my bov still works, but i noticed that when i'm boosting low, i have the same bov sound and not the different sound i had before. before when i boosted low and let off the throttle, it made a different sound than a high boost...could the second valve in this thing be bad? also, is it fixable? can you take these things apart and work on them?
thanks for the help
Old 12-03-2004, 12:17 PM
Igovert500's Avatar
blue + red light magnet
Re: broken bov?
What you described would be my guess as well...I know I've seen a site somewhere, where they took one apart...lemme do some searching.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-03-2004, 01:35 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
Re: broken bov?
pretty sure you cant take them apart. all that comes off is the cover
Old 12-03-2004, 07:19 PM
Re: broken bov?
thanks...it'd be great if you found the website cause i've searched all over
Old 12-03-2004, 07:38 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: broken bov?
sounds like a spring came out of place or somthing is wrong with the diafram....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-04-2004, 07:38 AM
Re: broken bov?
ok i took the bov back off to take a closer look....the clicking i was explaing was the little valve you can see when you look up through the bottom of the bov...the rod is purple and on it, is a little black thing that moves back and forth making the click sound....is this normal?
Old 12-04-2004, 05:26 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: broken bov?
HMMM.... BOV blows off and smacks the hood... might be time for a GReddy type-s...
