Old 12-02-2004, 10:02 PM
Ricky Gibbs Ricky Gibbs is offline
Post Flooding poblem after replacing 94 3.8 with 95 3.8
My daughter cracked the block on her 1994 3.8 liter v6 automatic, which was in her Mustang. So we found an engine at a junkyard, which is a 1995 of the same type. I understand that the 95 is compatible. After the mechanic installed it, he says it is getting to much gas to the cylinders. He can't figure out why. Please help us!! My daughter has been without a car for two months.
Ricky
Old 12-02-2004, 11:30 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: Flooding poblem after replacing 94 3.8 with 95 3.8
The Mass air sensor is probally shot or dirty. it's on the intake tube, Right after the air filter. The injectors are the same between both years.
actually the engine are the same for 94/95 and in 96 they had a very minor change. all the v6's form 94-98 are interchangable. The v6 shortblock from 99+ can be used with the heads and intake from 94-98.
My ride at my site Silverstangs.
Old 12-03-2004, 03:50 PM
Future303 Future303 is offline
ok, pardon my ignorance, but how do you crack a V6 engine with an Auto Transmission??
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 12-03-2004, 06:12 PM
Re: Re: Flooding poblem after replacing 94 3.8 with 95 3.8
  • Too much water and not enough antifreeze.
  • Engine tilting from worn out motormounts.
  • Rod being thrown from worn out bearings.
  • Cyclinder pressure from a valve stuck closed, and not letting exhaust out.
  • Head gasket leak, allowing antifreeze and water to mix, and ignorant car owner that keeps on topping off antifreeze.
  • Too much oil in engine, aka 7 quarts instead of 5.
  • Piston Slap
Old 12-04-2004, 10:16 AM
By my daudhter having her stupid boyfriend drive too far it after the headgasket blew.
Ricky
Old 12-21-2004, 08:29 PM
It ended up being a damaged harmonic balancer on the engine that was installed. Thanks for your help, though.
