Old 12-02-2004, 09:38 PM
bluehorse1968 bluehorse1968 is offline
Question Dtc P0121
I have a 1997 S-10 4 cylinder. It is getting bad fuel mileage and when scanned it comes up with code P0121 - TPS/Pedal Position Sensor A Ckt Range/Perf. Can someone tell me what I need to do to correct this problem ?
Thanks !!!
Old 12-02-2004, 10:34 PM
gbic1 gbic1 is offline
Do you have access to a DVOM? if so you may check the operation of the tp sensor at the throttle body by back probing the connector. You will be looking for a voltage of less the one volt at idle to about 5 volts at wide open throttle. Please check this with key on engine OFF! good luck. ( or you could just replace the tp sensor as a best guess, not that expensive)
Old 12-04-2004, 10:59 PM
Thumbs up Re: Dtc P0121
I changed the Throttle Position Sensor (TPS) and that appeared to have corrected the problem.
Thanks for the help !!!
Old 12-05-2004, 08:38 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Dtc P0121
lol,
1995 Factory Blazer Service Manual for sale, PM if interested.
