Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-02-2004, 09:12 PM
bitmeddler bitmeddler is offline
Send a message via AIM to bitmeddler Send a message via Yahoo to bitmeddler
Angry leak in rear foot well
Someone knows why the rear floor wells have water in them after a rain.....The doors are not the problem....Is it possible the water comes from the vents in the recess under the windshield????Need to know where to start troubleshooting this problem and the cure......Thanks....Ralph
Old 12-03-2004, 07:32 AM
6502dude's Avatar
6502dude 6502dude is offline
Hoist the car up and look at underside for rust thru & holes in floor - near foot well area or nearby as water will flow to lowest spot.
Floor panel rust thru is not have a much problems with in post 1980 cars. For FORD in the 70s, that is a different story.
Old 12-03-2004, 10:44 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: leak in rear foot well
Check all your door seals; if one is gone, water could be getting in that way.
Old 12-05-2004, 08:27 PM
Thanks for the info.........No rust or holes.....Ralph
Old 12-05-2004, 08:32 PM
Re: Re: leak in rear foot well
Thanks........All the seals are fine........I noticed recently that there is water in the vent to the rear that carries heat and air there........Someone has suggested that leaves or such have gathered under the windshield area and have clogged the drain areas and caused water to fill up and flow to the heating and air vents...Thanks for the info...Ralph
Old 12-28-2004, 04:35 PM
I FINALLY got this fixed.........There is a seal right at the bottom of the windshield when the grid there is removed...........This had cracked and the water was entering the vent which carries air to the rear foot well and getting that well full of water when it rained real hard.......Replaced the seal Hope this helps someone
