Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 12-02-2004, 08:30 PM
97fordexplorer 97fordexplorer is offline
97 Explorer Speedometer and odometer intermittently work
No speedometer cable. Uses new VSS that plugs into transmission. How do I check what's wrong? VSS? Wire to Cluster? Connection into the cluster? Thx
Old 12-16-2004, 08:37 PM
B33p3r B33p3r is offline
Re: 97 Explorer Speedometer and odometer intermittently work
Not sure if it will work but disconnect your battery for 10 minutes and reconnect. Sometimes the Modules get brain freeze and this resets them. I believe the General Control Module(GCM) controls the dash. Hope it works.
Old 01-15-2005, 08:42 PM
Poncho Villa Poncho Villa is offline
Hello!
I'm new here because I'm searching for a fix for the same problem. Were you able to determine why your speedometer works only intermittently? I've suddenly started experiencing the same thing. My speedometer works for a few days then suddenly dies. After a while, it'll start working again.
Mine has a 5.0 liter engine and automatic.
Please let me know if you've found what causes this.
Thanks!
Old 07-31-2007, 03:06 PM
Zagnut187 Zagnut187 is offline
I am also having this problem. Looked at this thread: http://www.automotiveforums.com/vbulletin/t150530.html
Old 08-01-2007, 09:45 AM
tseymour tseymour is offline
The speedo in my wifes explorer did the same thing. Her's is a 98 AWD. The plastic circuit board on the back of the dash seperates and does not make connection. I pulled it apart and added jumper wires from the connector to the speedo and have not had a problem since
