Old 12-02-2004, 08:26 PM
billyray63 billyray63 is offline
Just idle's .2000 Silverado
I just bought this truck and when I start it it just idle's. It can be cold or hot but there is no step up. The throttle works ok but to start it I have to push on the gas pedal a little or she starts hard. Also the gas gauge reads all over the place and I see from other letters it's in the tank but some times when it;s reading right and I turn on the headlights it goes down to empty. Could it be a bad ground.
Thank's
Old 12-02-2004, 08:41 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Just idle's .2000 Silverado
Thank's
There is no adjustment for the idle on your vehicle. try cleaning the throttle body with some quality cleaner and a soft tooth brush.
As far as the fuel guage goes, I have seen a lot of bad senders, but none with what you describe.
Quite possibly you could have a bad ground.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-02-2004, 08:55 PM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
Thank's
Does your truck have the fly by wire throttle or the electronic throttle? If it's a wire, there is an adjustment you can make with the idle screw. You can do some adjusting to it, then unhook your idle position sensor, turn the key on for 10sec so the computer will relearn the idle location, turn off the key, plug it back up, then it will reset the idle in that position to 0.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
