Old 12-02-2004, 08:01 PM
StillGoin5.0 StillGoin5.0 is offline
Send a message via AIM to StillGoin5.0
aternator ?
i'm looking into upgrading my alternator with a higher voltage one. now i wanna get one with at least 100 amps or more that will simply bolt and plug in. i just wanna add that i relocated my battery to the trunk, so i don't know if thats gonna affect the stock wiring or not with a higher volt alt. the car has a 800 watt audio system, with brighter headlights and fog lights. any input would be great thank you...
87 5.0 5 spd T-Tops - mass air conversion 9AL, msd distributer, coil, fms 9mm wires, bbk ceramic coated long tubes, bbk h pipe, 3" flowmaster catback, 190 lph fuel pump, 24 psi injectors, 70mm cobra meter, bbk AFPR, bbk fender kit with k&n filter, 12* base timing, flex fan, 3 row aluminum radiator, 6 piece headlight kit w/ clear corners, silver ponys, stormin normin cowl hood, saleen wing, and recently a new heater core
Old 12-02-2004, 08:25 PM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: aternator ?
www.paperformance.com... they sell the alternator i have installed. works beautifully, and only requires a couple crimp-on terminals to work (though you should go out and buy heat-shrink waterproof ones to be safe). that and a little bit of grinding on the alternator bracket, which can be accomplished with a drill and a rotary file if necessary. get the 4ga. charging wire to be safe, it hooks up to your starter relay and is easy to install.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 12-03-2004, 04:32 AM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
those alternators from paperformance won't bolt up to a 5.0 with out a little effort. the transition is simple and can be accomplished in under an hour, but get ready to do a little grinding on the brackets. make sure you get a warrenty as some of those third party alternators use a fiber glass insulator that tends to wear out.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 12-14-2004, 01:52 AM
glowstang93's Avatar
glowstang93 glowstang93 is offline
You can get an alternator that is used on 92 or 93 Ford Econolines or Trucks 95 or 130 that wll fit the same bracket. The wiring is the same as the ones from pa performance, but no grinding was necessary. All u have to buy is some connectors and a bolt for the stationary side.
1993 Mustang LX
2.3 4 cyl 105 hp
Reef Blue
Mods:215/60R15 Tires, 3G Alternator Upgrade, Removed Air Intake, K&N Air Filter, Tinted Windows, Upgraded to JL Speakers, JVC KD-AR3000 HU
Sealed Box with 2-10" 4000 MTX Road Thunder Subs, MTX Road Thunder RT202 Amp, JL 3.5, 6x8, and Pioneer 6.5 = 6 speakers, UnderBody Neons, Corbeau Sport Seats w/lumbar support,KYB GR2 struts/shocks
