Old 12-02-2004, 06:39 PM
kcjames19 kcjames19 is offline
zc headaces !!!!!! ecu problems
I SWAPED A dohc zc in my 91 civic dx dual point...
Which ECU would work best???... I"M now using a 89 integra auto>>AND it runs kind of crapy..
Old 12-02-2004, 06:59 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
that ecu should be fine...
what ecu codes do you have...if any?
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-02-2004, 07:08 PM
I"M not the engine dork.. I do bodykits and shit...
I have no clue..
Also today i was trying to ajust my idle speed and i guess i put it to low and the car died..
I tried to start it and it wouldnt turn over and my check engine light came on??????
Any ideas????????
Could i reset the ECU would that fix it..........
Old 12-02-2004, 07:14 PM
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Re: zc headaces !!!!!! ecu problems
I use the pm6 with my ZC and it runs... or ran nicely.
Travis
Old 12-03-2004, 12:46 PM
Re: Re: zc headaces !!!!!! ecu problems
I'm using the same one.... Mabye its the engine....
Old 12-03-2004, 03:40 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
no; if you are running a PG7(88-89 teg) Auto and you car is a five speed it is going like shit. i have had a PM6(88-91si) in my car and it ran fine, know i have a PG7 and it runs great.
My Name is Roberto AKA. Berto
Old 12-03-2004, 04:18 PM
I have a AUTO and is a PR4.... IS that bad??? ITs hard to find i auto 4 a zc....Which one i need to use?
Old 12-06-2004, 04:26 PM
that guy.'s Avatar
that guy. that guy. is offline
dont the 88-89 tegs use a lock up torque converter to shift instead of the ecu?
Old 12-06-2004, 05:40 PM
Hybrid1990crx's Avatar
it'd help if you told us how it runs "cappy".
did you check all your wiring for MPFI?
Old 12-06-2004, 09:39 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
is ur car standard or automatic? if its automatic then use an auto ECU. either a PM6 Auto, PG7 auto or PR4 auto. it should work fine. check the codes on ur ecu by counting the number of times it flashes consecutively without stopping/pausing. if it flashes 5 times. its a code 5. 9 times=code 9 etc... just keep counting because u may have more then one code. also, check the mpfi wiring and make sure u have the right plugs going to the right things.
