Old 12-02-2004, 06:32 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
headlight switch broke
went to turn off my head lights and i pushed the knob in and the whole assembly slide back, and i could pull it out, the switch has come loose from the dash. how hard is it to replace that?
Old 12-02-2004, 07:55 PM
jackmalone2001 jackmalone2001 is offline
If third is anything like fourth gen, then you have to take the dash cover (the large plastic piece from the windshield to the dash board) off, this will include removing a lot of little interior trim pieces, then remove the intrument bezel cover (the actual piece that covers your guages and such). Then you should be able to get to the switch from behind.
It is a staight forward job, but be CAREFUL when you are taking off the the dash cover because it sits in the sun all day and is BRITTLE!!!
Good Luck---go to the library and check out the Chilton for your specific model and see what they say and if you are comfortable--have at it.
before:
after:
Old 12-02-2004, 07:59 PM
Re: headlight switch broke
i was thinking of put some epoxy on the switch and just glue it back
Old 12-02-2004, 08:12 PM
you could try it but then you will have to worry about it. Do what you think is best but do yourself a favor and see how difficult it will be from the manuals first--then make your decision
before:
after:
Old 12-02-2004, 08:38 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
yeah id never had to deal with this untill i took my dash out, and i gotta say it is alot harder to get to than i would have thought. depending on how skinny your arms are, and how flexible you are, you might have to pull the dash forward away from the firewall to get to it, at least if memory serves correctly. not that bad, just a time consuming task.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 12-02-2004, 09:03 PM
lone wolf lone wolf is offline
but put the time in it and then you don't have to worry about it then
Old 12-02-2004, 09:13 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Pull the black plastic bezel off that goes around the wheel and gauges.. it just clips in at the top, I think there are two torx screws that hold it on the bottem
then you can get a better look of exactly whats broken and if you can get at it
1991 Camaro Z28
Old 12-02-2004, 09:25 PM
im kind of bulky and dont think i could do that. not that flexible, but ill try getting the face off. to turn them off i had to pull the fog light switch panel off and stick a finger behing the switch then push in the knob.
