Old 12-02-2004, 06:31 PM
crazy_quick crazy_quick is offline
Unhappy looow oil pressure !!!
I just want to know if the guages are acurate.
Because when i just cruse it is on the second to last line, it's very very low!
Old 12-02-2004, 07:44 PM
Igovert500's Avatar
blue + red light magnet
Re: looow oil pressure !!!
Check your oil level...using the dipstick...make sure you aren't leaking
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-03-2004, 03:35 PM
I have no leaks and the oil is fine.
what should i do now?
Old 12-03-2004, 03:56 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
So you wiped it off and did a clean reading and it was between the two notches? Its gotta be the sensor or the gauge is actually broken.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-03-2004, 04:13 PM
Igovert500's Avatar
When you are driving, and the car is warmed up, and you accelerate hard...does it go up significantly? Or stay low?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-03-2004, 05:19 PM
It moves up to the second or third notch from the bottom.
When i turn it on to warm up it has fine oil pressure and when i just criuse the oil presure drops.
Old 12-03-2004, 05:33 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
does it run fine though???
yeah my 300zx does the same thing. its the oil pressure sending unit. i just dont feel like fixing mine.
ZedEx Crew Member #4
Old 12-03-2004, 05:52 PM
It runs fine considering i dont have a front pcv, which i just orderd today.
when i turn it on the oil pressure is fine, but when i drive it the oil preassure drops to the first line
