Old 12-02-2004, 05:51 PM
kit88 kit88 is offline
Question dpfi to mpfi
Hi, I make the swap to MPFI civic 88 , I use the 1992 intake manifold and injectors, I´m am not using the resistor box, but I need help to connect the hoses of the manifold.
My big problem is that my car start but code 4 come on. I already check the wiring but is ok.
It seems that the time is not ok. Because the rotor is on piston # 3.
What I have to do to fix the problem
Please help me, this is my first swap and I need my car running.
Thanks.
Old 12-02-2004, 06:35 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: dpfi to mpfi
Thanks.
Sounds like you mixed up the c1 and c2 wires. You have blue/yellow at c2 and blue/green at c1 right?
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-03-2004, 06:37 PM
Re: dpfi to mpfi
yes, I have mixed up the wires, but now my car do not start because blow one fuse (the one that goes inside the car and says "alternator/solenoid" then I change the fuse and blow it again and again, somebody now whats happening???
Old 12-03-2004, 06:48 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: dpfi to mpfi
One of your wires is grounding out somewhere.
Old 12-03-2004, 06:53 PM
Re: dpfi to mpfi
I use a civic 92 intake manifold on my DPFI TO MPFI
but I´m having problems to connect the vacumm hoses .
PWhere can I get a diagram to connect the hoses???
