Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-02-2004, 04:52 PM
PP9966 PP9966 is offline
need help
i got a 96 integra se and i the code from the check engine light refering to misfiring cylinders 1 and 2. i changed the spark plug and wires, distributor rotor and cap, air and fuel filter and did an engine flush. the two cylinders are still misfiring...the mechanics i went to didnt know what else to do...anyone know what else could be wrong? thanks
Old 12-02-2004, 08:27 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: need help
did you reset the ecu ? check timing
Team Lonely Drivers
Old 12-02-2004, 09:39 PM
yea my mechanic already reset the ecu. just curious..whats timing? (not the timing belt right?) i dont know much about cars but i'm learning along the way
Old 12-03-2004, 07:07 AM
Re: need help
check dist timing, then line the crank to tdc and see if the cam is at tdc too, thats how you make sure its timing is good
Team Lonely Drivers
