One more thing...
Sorry I should have posted this along with the other post. The front doors starting at around 40 mph dont seal good enough, and therefore the wind noise is almost unbearable it seems to be just where the corner of the window meets with the seal, is there any kind of sheap ix fpor this problem, once again thanks to all for your help
Re: One more thing...
What year is the Neon? If its pre- 2000 then the door windows should be frameless. The best way is to replace the weatherstriping. A cheap way is to use some create a gasket. I used some on my old ford to fix the torn weatherstriping, and it worked pretty well. They make some for weatherstriping if i remember right ( i havent done it in a long time). Should be at your local parts store. Also check the window to see if they are loose. The tracks may be loose, and check the door hinges to see if they are straight. Open the door and see if you can move it by pushing it up. You shouldn't be able to. Thats all i can think of.
Well The car is a 1999, and the reason i am asking is because the weatherstriping look intact, sorry should hav cleared this up before.
Do you mean use the make a gasket stuff and reseal where the body meet with the weather stripping or place it where it meets with the glass? i try to look for new weaterstrpping prices also, thanks |
Where the glass meets the weatherstriping. That is almost always the problem with frameless windows.
Thanks for the help i wil give that a try and see if it works before i go and spend the money new stripping,
your window is out of alignment
this happens when people close the door by grabbing and pulling on the window to get it closed and puts stress on the window mecanism and it moves |
well how can i go about fixing this? is the any way to do it? sorry it is my GF's car and just trying to make it better for her, thanks
Ok well i can now see that the window is not aligned correctly, my first question is should i try to align the door it self or should try to align the window, by removing the door panels and all that wonderfull stuff, I figure the door would be an easier fix... Thanks to all in advance.
2001 GMC Jimmy SLS 2-door Manual Trans 2wd 120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla2007 Ford F150 supercab lariat 2wd |
Hey NeonStyl thanks for the link that is a Great site, thanks for pointing it out, i am defitnitly going to try that this weekend. good to you all.
