Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
Old 02-28-2002, 06:17 PM
Roadster2 Roadster2 is offline
Ford SVT Focus VS Honda Civic Si
They’re like combatants in the seminal arcade game Street Fighter II. (Huh? Sorry, but if you don’t get the analogy, you’re out of the demographic.) Each one is unbeatable if you’ve got the skills to master its particular talents. But each one also has inherent flaws. You decide which character to play, which one suits your style; neither can be a clear-cut favorite.
This is not a cop-out; the Ford SVT Focus and Honda Civic Si are an amazing pair. Driving them back to back, it’s hard not to love—or at least respect—both.
And the comparison is inevitable, as any prospective buyer should at least consider the other, no matter how dyed-in-the-wool Blue Oval you might be, no matter how many Civics you’ve already slammed. Ultimately, the cars’ different personalities are a good thing: more choice in a hot hatch segment that hasn’t had much.
At first glance, the cars seem statistically similar. The 165.6-inch-long Honda rides on a 101.2-inch wheelbase; the 168.2-inch Ford’s is 103 inches. The Civic’s track measures 57.9 inches; the Focus’ is 58.8 inches in the front and 58.5 in the rear.
FORD SVT FOCUS
Two-door hatchback
170 hp @ 7000 rpm,
145 lb-ft @ 5500 rpm 2.0-liter inline four, six-speed manual
Front-wheel drive
EPA combined: 22.9 mpg (est.)
Base price: $17,995
The Civic is 56.5 inches tall; the Focus, 56.3. Both front-drive, three-door hatchbacks are powered by 2.0-liter inline fours. The Honda makes 160 hp at 6500 rpm and 132 lb-ft of torque at 5000 rpm, the Ford, 170 hp at 7000 rpm and 145 lb-ft at 5500. The Civic weighs 2744 pounds, the Focus, 2750. These numbers—and the ones we’ll get in AutoFile track tests later—can’t tell the entire story; in both cars the whole is greater than the sum of the parts.
Under the hood of the Si, Honda has built what may be the smoothest engine ever. The word “slick” comes to mind.
It revs as quickly as the S2000 or the Acura RSX Type-S, but unfortunately, the Civic’s redline is only 6800 rpm. Prepare to find yourself banging the rev-limiter, but be glad that compared to the old Si motor, it’s actually got some torque. The Ford mill isn’t bad, but it’s rough like the standard Zetec on which it’s based.
It has more torque than the Honda and it revs to 7200 rpm, but it’s not quite as enjoyable to wind out. The Ford motor doesn’t idle as smoothly either.
What it does have going for it is the transaxle to which it’s bolted. The Ford box is actually a Getrag six-speed that shifts, well, like a Getrag. The Honda five-speed is good, as Honda manuals are, but the extra gear makes the Ford even more versatile in traffic. Sad that the Honda doesn’t have a sixth, as it could use it even more than the Ford, due to the Honda’s smaller torque output. Both transmissions shift smoothly with short throws. The Honda’s rally-inspired, dash-mounted shifter looks weirder than it feels. After a few shifts, you forget that it’s not in the “normal” location. Worth noting: Neither transaxle contains a limited-slip differential, something you can get in this class, in a Nissan Sentra SE-R Spec V.
Both the Civic and Focus chassis soak up bumps and handle off-camber jounces well, keeping the tires on the pavement and transmitting what’s going on through the seat. Neither car has much body roll, nor is there any sense that either manufacturer compromised a stiff ride to appeal to the mainstream; these are true sporting vehicles. Both cars can sometimes betray their econobox roots with a lack of rebound damping, but in this price range, neither suspension can be faulted. Both turn in well, with antiroll bars tuned to allow the back end to lighten up just enough to follow rather than push.
HONDA CIVIC SI
Two-door hatchback
160 hp @ 6500 rpm, 132 lb-ft @ 5000 rpm
2.0-liter inline four, five-speed manual
Front-wheel drive
EPA combined: 27.8 mpg (est.) Base price: $19,000 (est.)
While the suspensions have similar handling characteristics, the tires couldn’t be more different. The Focus has massive, grippy 17-inch Continental summer tires; the Civic is shod with much less aggressive 15-inch all-season rubber. Yet when it comes to cornering, the Civic’s less aggressive tires work with its suspension just as well as the Focus’ tires do—two different ways to achieve the same goal. Where the Focus’ bigger tires shine is in their ability to stop and start the car. The big tires are nearly impossible to overpower off the line, and bring the SVT to a seatbelt- jerking stop with a level of confidence not found in the Civic. Considering the Focus has 11.8-inch front discs while the Civic’s are only 10.3 inches, it’s small wonder.
On the inside, the Civic has the superior wheel and seats, both of which feel more like they were yanked from a race car than those in the Focus. But the Ford dash has more style and the Focus has better sightlines from the driver’s seat. If back-seat room is important, the Civic feels larger. All the materials in these cars are of expected quality: plain and simple. The Civic has a standard sunroof that you regrettably can’t opt to delete; the Focus’ sunroof is optional.
Chances are most will find their biggest points of contention with either car in the exterior styling. The SVT team has taken some of the edginess out of Ford’s “New Edge” styling with different fascias and rocker moldings. This makes an awkward car look tougher, but still far from the smooth style of, say, a VW Golf. At least the SVT Focus isn’t boring, something that can’t be said for the Si.
Its nebulous lines might be just the platform for aftermarket body kits, but without them its huge windshield screams mini-minivan. If Honda isn’t going to let us have the Civic Si Type R in the United States, at least it should give us its fascia and body skirt.
Overall, the Focus feels like it was fashioned from a well-selected batch of aftermarket parts. That’s a good thing, but the downside is that the car doesn’t feel as finished or from-the-factory as the Civic. The Ford is rough, it’s got a loud exhaust, overkill tires, and feels like a mini-muscle car; you realize immediately it is built by the same people who craft the SVT Cobra. On the other hand, the Honda is truly a Honda, which is to say it’s a relative of the S2000 and Acura NSX and you can feel it in the fluidity and precision of the powertrain and suspension. The only real caveat with the Si is that it could use a louder exhaust—and most buyers will probably fit one. The Ford carries no real complaints, but we wouldn’t be surprised if you find yourself, or your dealer, turning a wrench on the SVT Focus more frequently.
The bottom line is both cars are fast, handle well and are an absolute blast to drive. These are great cars, especially considering the price. The Ford SVT Focus has a base MSRP of $17,995 including destination; Honda has not finalized prices of the Civic Si, but it is expected to sell for about $19,000. You can’t get more bang for less bucks, at least outside of the world of video games
MY PICK IS STILL THE SVT FOCUS
http://www.fordfans1.homestead.com/FORDFAN1.html
