Old 12-02-2004, 01:20 PM
Yungstar007 Yungstar007 is offline
Send a message via MSN to Yungstar007
Unhappy Screeching/whining sound when starting up
Hi everyone. For the past couple days now I've been experience a pretty noticeable screeching/whining sound the second I turn the ignition on with the clutch depressed. It goes away when I raise the clutch but today it actually continued a few more seconds after I raised the clutch. Could it be a throwout bearing? It only makes this sound when starting the car up. It's been getting quite cold up here lately so could that be a reason? Recently got the car about 3 weeks ago from a Mitsu dealership. Hope I haven't already messed something up. Got a warranty on it but to use it already would be quite embarrassing, heh. It's a 98 Talon TSI AWD. I'm new to the DSM market so any advice would be greatly appreciated. Thanks in advance.
Old 12-02-2004, 01:27 PM
n8s95gsx n8s95gsx is offline
Re: Screeching/whining sound when starting up
Same problem, i took it to my local performance shop and its my alternator. it shouldnt do it just when the clutch is down though. maybe it just seems like it because its down when u r starting it up.
Old 12-02-2004, 01:33 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Check to see if the crank pulley wobbles as well.
Kris
2012 Genesis Coupe 2.0t
Old 12-02-2004, 05:19 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
it sounds like either a bad belt or a loose belt.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-02-2004, 06:37 PM
Vtec95Civic Vtec95Civic is offline
I'd have to say belt too.
Old 12-02-2004, 09:44 PM
Harder Faster's Avatar
Harder Faster Harder Faster is offline
It is possible that it could be your power steering pump. Try spraying some kind of lube in between where the pulley for the powersteering meets the pump. If the squeeking goes away, then you've found your problem. If that doesn't work, tighten your belts.
\Sleep"er\, n. 1. One who sleeps; a slumberer
Old 12-04-2004, 11:48 PM
96RSeclipse 96RSeclipse is offline
Send a message via AIM to 96RSeclipse
might wanna try to replace the belt. if the belt is your problem, it should squeel if you rev the car real hard.
