Old 12-02-2004, 12:55 PM
nhancock nhancock is offline
Dodge Caravan won't start
My wife pulled the van into the garage last night and it worked fine. This morning when she went to start it, it would not start. There is fuel but no spark. A friend of mine is a mechanic and he braught his tester over and it indicated a bad Auto Shut Down Relay. After replacing this the van still won't start.
Any ideas where to go next?
Old 12-02-2004, 07:12 PM
Terri1228 Terri1228 is offline
99 Caravan won't start
The same thing has just happened to my caravan. Worked great today, came home and parked it. Went to run an errand and it won't do anything. the ignition is now locked also.
Any ideas??
Old 12-02-2004, 08:03 PM
vipergg vipergg is offline
Re: Dodge Caravan won't start
Does it crank over at all ? If not I have seen batteries do this , you drive it , park it and the next time it won't start at all .
Old 12-02-2004, 09:08 PM
sammy2 sammy2 is offline
Send a message via Yahoo to sammy2
It is not uncommon when the weather gets cold for this to happen [battery].
Old 12-03-2004, 09:01 AM
It turns over. But it never starts. There is fuel. But no spark.
Old 12-03-2004, 11:08 AM
Am I correct to assume you put jumper cables to this vehicle?
Have you checked fuses? Don't laugh....it can be so simple.
Old 12-03-2004, 09:10 PM
Cobra_Sam Cobra_Sam is offline
Re: Re: Dodge Caravan won't start
You have not mentioned what year and model it is. (engine size)
Old 12-04-2004, 06:44 PM
lcga lcga is offline
I have had this problem with a 1992 Dodge Caravan 2.5L. First it was because the timing belt had gone bad. The engine at that time seemed to crack really easy---but no spark. It cost me about $200. to have a friend replace the belt. But now, I also have it not starting but it's because the fuel pump has gone out! Good Luck!
Old 12-05-2004, 09:57 AM
jormeinmi jormeinmi is offline
Send a message via Yahoo to jormeinmi
Question Re: Dodge Caravan won't start
i have same problem i need to find the location of the relay can u help wwhich one is it ty
Old 12-06-2004, 08:26 PM
Jormeinmi,
Get online and go to: autorepair.about.com/library/illustrations/bl043a-lib.htm They have the schematic for the Caravan. Or to make it easier, search Google search Dodge Caravan fuel relay schematic. That's how I located the relays.
Hope it helps!
lcga
Old 12-27-2004, 12:15 PM
ALONZO24 ALONZO24 is offline
I Have The Same Proble Just Quit On My Wife, No Spark Fuel Ok - I Thought It Was The Ingnition Coil But I Called Friend Of Mine That Swaped The Eng On It, He Said It Is Common For The Crank Sensor To Cause That Sure Enough The Coil Works I Have Yet To Switch Out The Crank Sensor
Old 12-27-2004, 02:54 PM
Thank you, can you tell me something about 'crank sensor' ...where it is located and just what it's function is? I was loaned a probe light to test a brown wire but do not know where it is. Also it starts okay but dies immediately, like it is choked out of fuel. Fuel injectors were changed, plenum & parts cleaned of carbon. it is an 87 Ply Voy 6 cyl 3.0
Old 12-27-2004, 04:30 PM
The Crank Sensor Tells The Comp That The Veh Is Cranking Then Starts The Rest Of The Normal Functions Like Sending Power For The Spark. Now As For Yours That Starts Then Dies You Might Be Running Lean Check Your Fuel Pressure
Old 12-27-2004, 05:31 PM
Ana Little Ana Little is offline
I had the same problem with my 88 Plymouth Voyager. After it would set for an hour or two it would start again. I took it to the shop and it had a short in one of the wires connected to the fuel pump. I had the whole fuel pump assembly replaced and haven't had that problem since. I'm not an expert by far, just sharing how I was able to fix a similar problem on mine.
~Ana Little
Old 12-28-2004, 11:55 AM
You Might Want To Also Check The Relays. Check For Power Going To The Injectors Aswell.
