Old 12-02-2004, 12:37 PM
pr0ject01's Avatar
pr0ject01 pr0ject01 is offline
Send a message via AIM to pr0ject01
Engine Questions
Notice how the headers all the paint is chipping off and looks really bad.. how can you get them .. chrome.. and shiny..? Im not good with engine area.. so bare with me.
Also all the plugs and everything.. i want to change the color of them.. to like a blue.. does anyone know where I can find them at..?
One last thing, to clean out your engine area to make it shiny and what not.. can i just use regular degreaser..?
1991 Dodge Stealth R/t
Old 12-02-2004, 12:42 PM
Igovert500's Avatar
blue + red light magnet
Re: Engine Questions
Well for some reason, I can't see the pic you posted...but I know on my honda header...they came painted black and within 50 miles the paint burnt off, and now they are white/rusty...nothing that I know of that will change that.
As far as colored plugs...I assume you mean the wires, as plugs aren't colored...check out the shop sites in the FAQ, like 3sxperformance.com, and look for engine dress-up kits...typically they have colored wires, or colored tubes you can wrap wires, vacuum lines and stuff in, to make everything more colorful.
Lastly, as far as making you engine shiny...get engine degreaser, and go to a local do-it-yourself car wash with power washer...spray the degreaser liberally, but keep it away from electric stuff like distributor cap, plugs, etc. Then use the power washer to spray it all off...just be careful...I did it on my engine and it removed a bit of the paint on one of the valve covers and the oil cap.
Oh, also get a plastic bag and a large rubberband and seal up your entire intake...so no water gets in there either.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-02-2004, 02:34 PM
Stealth93 Stealth93 is offline
Do you mean the paint chipping off the intake plenum? I see it badly chipping off of that....or do you mean the heatshield covering the front exhaust manifold?
-If you meant the plenum, i cleaned mine off by taking a razorblade and gently peeling off the main pieces and then i went over that with a wire brush. It comes pretty good. But if you want, for $150 you can get a new one thats chromed. There is a core charge on it though (you have to give them your old one or else they charge you more money.) You can get them on 3sxperformance.com
-If you meant the heatshield-you can take it off and clean it up, and then spray it with high heat paint.
Old 12-02-2004, 02:54 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
to get colored wires, or dress up your engine, there's a few ways of doing it.
while your at it you might as well get some spark plug wires in the color that you prefer which i think you said blue(funny thing is, mine are blue). some people get everything chromed out or like igovert500 said you get the material to wrap over it to the point it would look like the original tube.
you can try these guys out as they don't seem to be to far from you
altered atmosphere (301) 330-8835
Old 12-02-2004, 08:28 PM
$hott-boi$ $hott-boi$ is offline
check out www.3sxperformance.com
they have some stuff to chrome out ur engine and i think they have multi color'd wires as well
Old 12-03-2004, 12:23 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
its not chromed, its polished
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 12-03-2004, 01:47 AM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
1. Where you would see your front header.
2. Throttle body.
3. Intake box.
4. MAS.
5. Intake plenum.
6. Spark plug wires.
7. Spark plug cover.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-03-2004, 03:26 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Thumbs up
Now that was an informative drawing for anyone to follow.
Resistance Is Futile (If < 1ohm)
Old 12-03-2004, 07:56 PM
StealthModifier StealthModifier is offline
about the header cover, mine looked like that, just sand off the rust and smooth out the whole piece. then get some silver VHT high temp paint from autozone and put a few coats of that on it,mine is still holding up. u can also use the same paint on the plenum, thats what i used on mine. looks a lot better than that brown coat that peals off
check out the link in my sig.
