Old 12-02-2004, 11:40 AM
MetalTwitch MetalTwitch is offline
Send a message via AIM to MetalTwitch
Motor Swap
Ok so when my VR4 motor blows i'm thinking of puting an sl motor with new turbos in. What do i have to do to get the sl moror tt? Would my intake maniforld of my vr4 fit on an sl? Do i have to change the pistons? what do i got to do to the sl motor?
Old 12-02-2004, 11:50 AM
pr0ject01's Avatar
pr0ject01 pr0ject01 is offline
Send a message via AIM to pr0ject01
Re: Motor Swap
Why would you want your engine to blow in the first place..? That could lead to more damage in other area's. Why dont you just sell your engine now, take the money you get from your engine and buy a new one.
1991 Dodge Stealth R/t
Old 12-02-2004, 11:57 AM
Stealth93 Stealth93 is offline
If I'm not mistaking, I believe SL motors have a 10:1 compression ratio, and Vr-4's have an 8:1 ratio. You may experience more knock with the SL motor as opposed to the VR-4 motor depending on how much boost you wish to run. Also the the front motor mount bracket on N/A motors has to be changed to make way for the front turbo. You'd also have to swap exhaust manifolds, the oil housing, water housing, and oil pan. I think your VR-4 intake manifold would fit the SL motor. You may already know this stuff, but in case you don't, I hope I've helped a little bit.
Old 12-02-2004, 12:27 PM
Igovert500's Avatar
blue + red light magnet
Re: Motor Swap
Why would you want your motor to blow...and why would you want to tt an NA engine instead of just dropping in a new vr4 engine?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-03-2004, 09:44 PM
3000-G_T_S_L 3000-G_T_S_L is offline
Send a message via AIM to 3000-G_T_S_L
Re: Motor Swap
I sorta want to do the same thing. I have a normal SL and I'd like to put turbo in it. But my only problem is that I have an automatic, and 3s are so very rare here that I had to take this one when I found it. I'm no automotive genius, but is it extremely harmful to the engine to turbo an auto?
1999 Pearl White 3000GT SL - Sold
1992 Dark Green 3000GT VR4 - Spun Bearing
2006 Black Suzuki Katana 600cc -hit from behind, totaled
*JUST BOUGHT*2008 Red Mitsubishi Lancer ES - planning
Old 12-03-2004, 10:11 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Motor Swap
There are a few guys who have TT'ed auto's. The big advantage is brake boosting. A major drawback is you cant use the TT ECU because it cant control th eauto tranny.
Old 12-03-2004, 10:29 PM
Re: Motor Swap
hmm,I understood all of that except the ecu, how does that effect the TT?
Old 12-03-2004, 10:32 PM
Stealthee's Avatar
Re: Re: Motor Swap
Well its been dyno proven that a TT ecu will give you 50hp. It has something to do with the fact the NA ecu cant compensate for positive crankcase pressure. Its a bigtime advantage ruuning the TT ecu. Another thing is the TT ECu is already set up for 360cc injectors. If you dont run the TT ecu you have to run some kind of AFC to control the injectors.
Old 12-04-2004, 02:43 PM
Re: Motor Swap
so I wont be able to use the TT ECU, but I can turbo my auto? and how much HP do you think it'll add?
Old 12-04-2004, 04:12 PM
Stealthee's Avatar
Re: Re: Motor Swap
If you use stock 9b turbos you can look at around 40-50hp at the wheels, best guess, maybe more. If you turbo your auto you are also stuck usin the 10:1 block. If you want to use lower compression pistons they have to be swapped out.
