Old 12-02-2004, 11:06 AM
engrtech engrtech is offline
1987 Jeep Cherokee Electrical Problem
I have a '87 Jeep Cherokee 4.0 4WD standard, the original altenator went out at 133k miles and I replaced it but now the amps will not stay high enough to run the system and cooling fan. Does anyone have any ideas? Also I replaced the injector seals and now can't get them all resealed to stop the fuel leaks.
Old 12-03-2004, 02:40 AM
IdahoJeeper's Avatar
IdahoJeeper IdahoJeeper is offline
Re: 1987 Jeep Cherokee Electrical Problem
Before you lost the other alternator, was it puting out enough juice? It almost sounds like you have a heavy load out there in your system somewhere dragging your alternator down. No blown fuses or burned wires anywhere?
On your o-ring problem, I've used a little bit of Power Punch smeared on the o-ring to help it slide and seat properly...
You like jazz, she likes Klingon opera, so you compromise - you listen to Klingon opera...
You like Cherokees, she likes Grand Cherokees, so you compromise - you buy a Grand Cherokee...
Old 12-03-2004, 08:13 AM
Re: Re: 1987 Jeep Cherokee Electrical Problem
I have checked the entire system and have not located ay blown fuses or burned/bare wires to cause a short.
