Old 12-01-2004, 10:34 PM
pro3racer pro3racer is offline
Throttle Body replacement
I'm about to replace my throttle body, and i want to know if there are any special procedures i need to do, or anything to watch out for. I also would like to know what the gasket number where it attaches to the intake mani. I know people say you can re-use it if your careful, but i'm just going to replace that too, if possible i mean.
1991 Eagle Talon ESI, manual, 2.0 FWD
1992 Eagle Talon TSI, manual, 2.0 FWD
Old 12-02-2004, 09:14 AM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
Re: Throttle Body replacement
what's the problem of the throttle body? most likely you can replace the individual parts of the TB instead of the whole thing. it's expensive to buy a whole TB.
you can get the gasket from the dealer, not sure about the part number but tell them that you want a throttle body gasket for you year model of car.
you can really reuse it. if it's metal, you can defiintely reuse it.
06 Charger SRT-8 black.
Old 12-02-2004, 04:22 PM
I've replaced everything, from plugs/wires, to all the hoses, to the TPS, and i still have idle surge, and i'm getting the new TB for $40. I would much rather just replace it, get my car running right, and then go and take apart the old TB and find the error.
Old 12-02-2004, 05:48 PM
Scoped_GST Scoped_GST is offline
Send a message via AIM to Scoped_GST
yea, i was thinkin about it since a friend i know would sell me his 91 TB and Intake Manifold for $100. Is it pretty hard to put on a 2G if you do both together, and is it really worth it?
Old 12-02-2004, 07:52 PM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
try the idle speed controller, it fixed mine.
Old 12-02-2004, 11:03 PM
Can i check to see if the ISM is bad? I'm guessing it's the little motor looking object, across the TB from the TPS. Or would the ISM come with the TB?
Old 12-02-2004, 11:17 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
im selling you the whole thing with all the sensors
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-02-2004, 11:22 PM
ahh, thanks, that'll make me sleep well tonite. I heard that you lose quite a bit of coolant when doing this, is that true? I have a radiator leak, so that would probably be a good time to address both.
Old 12-02-2004, 11:28 PM
you dont lose much just wrap some rags around the hoses and clamp them with a pair of vise grips before you unhook them.
-1stGenRocks-
Old 12-02-2004, 11:41 PM
okay, sounds good. Just want to mention i hate winter!!! why can't i live in the south, why?
Old 12-02-2004, 11:49 PM
lol i just want to have my tsi fixed for this winter. 88 bronco 2 with 2wd sucks balls in the snow
-1stGenRocks-
