Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 12-01-2004, 09:20 PM
integraboy_2007 integraboy_2007 is offline
GS-R or LS/vtec
Ok i know everyone has heard these tyes of thread before but i got a 93 teg and wanted to know if i was better off doing a ls/vtec or get a gs-r swap, I've heard ls/vtec gives a lil more power then a gs-r but isn't reliable if it isn't done properly. Also money is an issue and the cheaper the better for me.
Old 12-02-2004, 02:12 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: GS-R or LS/vtec
lsvtec will be cheaper then a gsr. main things i would replace would be the oil pump and rod bolts. also get it tuned because no stock ecu is made to handle the extra displacement of the ls bottom end. but if you cant afford that, the gsr ecu would be the closest.
Team Lonely Drivers
Old 12-02-2004, 05:29 PM
Re: GS-R or LS/vtec
yea thnk well now i'm plannign on doin an ls/vtec since i found a real cheap deal on a gs-r head
Old 12-30-2004, 08:05 PM
civicturbo civicturbo is offline
Send a message via ICQ to civicturbo Send a message via AIM to civicturbo
Thumbs up Re: Re: GS-R or LS/vtec
sup man im doing droping an ls block and a hydraulic gsr transmission in and a full greddy turbo running 9:1 compression with srp pistons and spoon sport cams and cam gears. should i put a vtec head on it i also have a full gsr motor just sitting in my shope wondering wat i need to do with it. just let me know man. Charlie
Old 12-30-2004, 10:57 PM
Medabots Medabots is offline
Now give some advise
I just got a 95 integra ls B18b1 engine, where should I go from there?
I was thinking about a GS-R head or a Type-R..... just give me your advise....
Old 01-04-2005, 01:12 PM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
Re: GS-R or LS/vtec
civic turbo, take head off gsr put on ls, be happy, medabots, use type r head if u can find it,.....if u cant afford it, do gsr head....ls vtec is ohk, but gsr or type r motor is better in the long run
