dual cooling fans
how could i hook up a dual fan set up on my 90 camaro, will the dual fans just have one flug for both or do i need to modify the harness.
Re: dual cooling fans
each motor has its own two wire plug..
go to a junkyard or something and grab another plug with a couple feet of wire on it.. just long enough to solder it into the existing harness
1991 Camaro Z28 |
that wont strain my relay or temp switch will it?
hmm.. good point..
well what ide do is get a 30amp SPDT relay (about $1.00) and wire it up... Use the power wire from the first fan as the trigger, than run a (fused) 12v right from the battery or fuse box to the relay to power the second fan.. ground the relay and ground the fan.. this way it isnt drawing any amps off of the original fan circuit, but when your original fan turns on, it will open the path from the battery to the second fan
1991 Camaro Z28 |
hmm, good idea. you are the mack daddy
i dont need you to tell me that!
here.. I dug this up if you need a guide to wirin that relay in http://www.the12volt.com/relays/relays.asp
1991 Camaro Z28 |
thats a damn good idea damone. me thinks i might have to look into that...
*Better power-to-weight ratio than a C6 corvette* |
damone im going to try your idea this weekend.
cool.. let me know how it works out
1991 Camaro Z28 |
that sounds cool i'm going to look in to that as well thanks
lone wolf |
