help
i have been working on a 200 impala and i am changing the plugs(go ahead laugh it up now) i can get the first three up front fine but i go under it i can get (frombottom view ) the right 2 plugs but the far one was a pain in the a$$ is there any easyier way to get them bottom ones it took e like three hours on the last one
thanks ~shawn |
Re: help
put on the E-brake and shift the car to neutral.
Disconnect the two front wishbone engine supports, now you can rock the engine forward about 4+ inches. edit to add: I mean dog-bone, not wishbone. And emphasizing that the engine rocks much further forward if the car is in neutral. Last edited by kuhurdler; 12-05-2004 at 01:52 PM. |
Re: help
either that or put a jack under the trans pan, remove the upper engine mounts, then jack up the trans to roll the engine forward
Re: help
I don't think it's that hard to get to that you would have to do all that extra work to replace the spark plugs....
mike |
Re: help
Yes, removal of the dogbones is standard proceedure on most GM front drive V6 engines when changing plugs. Good Luck.
![]() Yes, I am retarded. |
Re: help
just move the power pack and you can reach them jsut fine. I did! 4 bolts hold it on.
