Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-01-2004, 07:46 PM
ScottN3N ScottN3N is offline
Angry Rear Diff. locking up
Hi, I've got a 99 GMC Suburban, 2500, 4WD, Vortec 7400, 100k miles, towin pkg, etc. I'm 95% sure it has a limited slip diff. The rear end is locking up all the time. It's very noticable around a tight corner. I made sure the 4wd is disengaged (checked the engaging actuator in the front axle) to elominate that as a problem. I changed the fluid - used the correct (very expensive) GM gear oil. Did not see anything out of the ordinary (broken pieces, etc.) in the housing. I have tried making "S" turns in reverse, forwards, backwards/forwards, driving in circles, etc to try to free up whatever is stuck. It refuses to release. Anybody have this problems, any ideas, please? It does not make any whining noises or vibrations, the only noticeable problem is that it is not doing the differential thing around corners. Help - I'm stumped
Thanks for the help. Dito on the intake manifold problem. It's also a problem on the big block engine.
Old 12-01-2004, 11:00 PM
the blur the blur is offline
add 2 bottles of the GM limited slip additive.
Old 12-02-2004, 07:09 PM
I used the specified GM fluid ($26.00/quart) that is supposed to be for that rear end and have the additives. Are you saying I need to add 2 more bottles of additive to that fluid?
Old 12-02-2004, 08:01 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
I think you used the wrong lube...it sounds like you installed synthetic lube.
here is the correct part number
Rear Axle (Locking Differential)
SAE 80W-90 Axle Lubricant; use only GM Part No. 1052271. Do not add friction modifier
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-02-2004, 10:09 PM
Re: Rear Diff. locking up
why would you NOT use friction modifier on a limited slip rear?
I know some the GL5 lubes say not necessary, but then they chatter.
Old 12-03-2004, 05:08 PM
The part # they sold me is 89021677 - sounds like the wrong stuff @%$#^@$. Is that rear end pretty bullet proof, or are they prone to doing this. I figured new fluid should fix the problem. I do a moderate amount of towing, about 3-4 trips a year. I'll go back & get them to straighten this out. THanks.
Old 12-05-2004, 05:42 AM
GMMerlin's Avatar
I know stuff
Gm has determined it is not necessary with this lubercant
Sounds like it.
Those differentials are fairly bullet proof.
When I service a differential, after draining the fluid (cover off) I clean the inside of the diff with some brake cleaner to remove any old dirt that may be still there.
After I fill the diff, I drive it a nd immediately do 3 or 4 turns (usually in a circle one way then the other) to work the lube into the clutch packs
GM WCT
PM Me for details
