| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
95 Cutlass Steering thunk
Hi,
I have a 95 Cutlass Supreme. I have replaced both outer tie rods. The car would pull to the left, like it really needed an alignment badly. But, when I turned the wheel sharply to the right, I heard a thunk and it straightened out the steering, and the car didn't pull to the left anymore. When I made a sharp turn to the right, I hear a thunk noise. Now, it's whether I turn right or left, I hear the thunk noise. It seems to be getting worse. Does anyone know what it is, what it could be, and if there's a danger with driving it like this? Thanks. |
Hi,
Some additional info, the car seems to shake at times when going 60 + mph. Thanks for reading. |
i had this problem to .found both bolts loose that attach the steering rack to the frame. hope this helps.....
Thanks for the reply!
I also found out that the power steering fluid gets low fast, which means a leak! I'm getting an estimate from the mecanic, and I'll update you on the results! |
A quick update after seeing the mechanic:
He told me the upper bushings where the strut connects on top are totally gone. He also said I need to replace the right ball joint, and new brake pads! So, all in all it isn't too bad! |
