Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 12-01-2004, 05:54 PM
sjkelsey sjkelsey is offline
98 Durango starts, but won't idle
Love this site. Have problem with 98 Durango. Starts, but unless I keep gas pedal depressed, engine stops. Had to have it towed. Dealer could not find anything wrong. On this site, I found 3 similiar situations. All turned out to be battery problem, even though battery appeared OK. I am replacing battery tomorrow. Keeping my fingers crossed.
Old 12-01-2004, 07:00 PM
DurangoDave DurangoDave is offline
Re: 98 Durango starts, but won't idle
I'd clean and re-make the battery connections, and get the battery tested before making my first response the spending of 50+ bucks on a new battery! (But maybe you've already done that...)
Dave
Old 12-01-2004, 08:07 PM
Your advice is probably correct. But,
Battery is probably close to 4 years old. Would most likely need to replace in the near future. Lucky I was in work parking lot when issue first surfaced. Dealer still has Durango and says could not find anything wrong.
Old 12-06-2004, 07:18 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Probably the throttle position sensor that is out of whack, or your idle air control valve isn't working at all...
If it starts and won't idle, it should be obvious to the dealer that there is something wrong, no?
My Mopars
Old 01-11-2005, 09:10 PM
ezmonster ezmonster is offline
Did you ever get this fixed? My 2000 durango is having the same problem. It will start but I have to throttle it to keep it running. I have a new battery. I can't figure it out.
Old 01-12-2005, 01:51 AM
code3 code3 is offline
Re: Re: 98 Durango starts, but won't idle
Must be bad if the dealer doesnt even know or cant find the answer to this problem. If you have auto start or recently worked on your vehicles wires, re-check you wires and battery.
Old 01-31-2005, 11:48 PM
I got my idle problem fixed. I took my battery to Autozone and had it tested. It was deader than dead and would not charge. After I replaced the battery I still had the same problem. So I played around with the battery wires and made sure that they were all tightend properly and that fixed it. Good luck to anyone that has this problem.
Old 02-11-2005, 10:38 PM
lds540ans1 lds540ans1 is offline
It's the battery been there done that........!!!!
