Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-01-2004, 05:43 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Question 4G63 compression?
About 2-3 weeks ago I was doin some drivin-HWY, easy goin. Wife and I went looking for new vehicle for her... got to a dealership and got out to look at something... I noticed some bluish smoke (smelled like oil)coming from the muffler.
I did a compression check on all 4 and they all were at about 105 psi.
My thoughts of the rings goin bad/burning oil were set aside.....
My question is what are they supposed to be/PSI? and what else would cause an oil burning problem? Valves?
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 12-02-2004, 02:49 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: 4G63 compression?
http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
DSM geek
Old 12-02-2004, 03:16 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
where can you get a compression gauge at btw?
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 12-02-2004, 05:36 PM
Re: Re: 4G63 compression?
Checker, Napa, wherever
OK here is info for me....
2G (95-99) 2.0L 4G63 Turbo engine
Compression ratio 8.5:1
Standard compression 178 psi
Service limit 133 psi
Is the service limit what I think it is... if it's less than 133psi it needs to be fixed?
I'll have to do the check again... hopefully I end up with more than 105 psi again!!!!! Maybe thats my power loss I feel when boosting at 12-13.
Old 12-02-2004, 06:13 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
it could be your rings. does your dipstick pop out when you boost? when you do your compression test do a dry then a wet test. first check it normally (dry test) then pour a tablespoon of oil in each spark plug hole wait a few minutes and test the compression again (wet test). if the compression goes up that means your rings are going bad.
if you have the machine for it you can also do a leakdown test which involves filling the cylinder with compressed air and it gives you percentages for where it leaks out from. 10% from the rings, 10% from the intake valves, 10% from the exhaust valves, etc...
edit>>> yes you are right about the service limit. the compression shouldnt be lower then that
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-02-2004, 10:26 PM
Re: Re: Re: 4G63 compression?
Thanks a lot man! Didnt mean to interfere with your thread .
My Car
Old 12-05-2004, 01:05 AM
OK... did another test today.... If you are looking at the engine from left to right my readings were as follows....
175psi...170...165...150.
I found it odd that they went down like that.... I suppose that could cause some of the powerloss feel...... Heck of alot better than 105psi I had the first time!!!! lmao
Thanks guys!! Any suggestions or thoughts please spill it.
Old 12-05-2004, 04:50 AM
joemathews's Avatar
joemathews joemathews is offline
Just to make sure....
1) You did the tests on a warm engine (at or near running temp)
2) You allowed for 4 full rotations while cranking
3) You held the gas pedal at WOT while cranking
If you did all of that, you should have a decent compression reading.
I also have the burning oil problem--not a huge cloud of blue smoke following my car, just a little puff now and then when taking off from a stop, or revving the engine in neutral. Possible ways to burn oil are:
1) bent valves/bad valve stem seals
2) bad piston rings
3) bad turbo seals
4) bad PCV valve
I am investigating these on my car as well. My compression numbers are 180-170-175-180. I can't imagine having compression numbers that high with bad rings or bad valve stem seals, but I am no expert in the area. I'd be interested to get Kevin's opinion though.
Next on my list is replacing the PCV valve ($5, easy to get to). The turbo will also be replaced soon enough . I just can't wait to finish the 4 finals and 3 papers I have due in the next 12 days so I can get this stuff sorted out.
1996 Eagle Talon
