Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-01-2004, 04:23 PM
marsalis83 marsalis83 is offline
Unhappy still rough 429
what are the symptoms of a burned valve or severe carbon buildup? just wanna know if I may need to clean her out with some strong cleaner.
Old 12-01-2004, 04:25 PM
Re: still rough 429
Don't know if its something dire, but the car still runs real nice. it's gotta be something simple or at least something that doesn't require severe surgery.
Old 12-02-2004, 08:02 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: still rough 429
I forgot, have you done a compression test on the engine? New Carb? Tune up?
Old 01-14-2005, 10:16 AM
Re: still rough 429
what if i have a kinda gurgaling sound coming from my valves at full throttle? are the seats or guides worn? or is it the rings?
Old 01-14-2005, 10:20 AM
Re: still rough 429
i have had a professional tune up, and a new carb, but that isn't the problem. anymore. ive narrowed it (with professional help) to a HUGE VACCUM leak. Thank god. Now I just need to know what's up with my valves. I have replaced or recalibrated just about everything under the hood except the valves and cylinders and the motor is in too good a shape to have shot cylinders.. It has just been sitting, so my seals may be bad.
Old 01-14-2005, 10:26 AM
Re: still rough 429
Gurgling? And at full throttle only? Sounds funky; are you sure it's not the air intake or something?
(glad it's just vacuum, that makes it easier, or at least cheaper)
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-14-2005, 11:01 AM
Re: still rough 429
Yeah. It does it when I am on the freeway, and I need to speed up to pass or just cause I am cruising. would fuel grade have anything to do with this? I don't drive like a speed demon, but i know what the thing should do.
Old 01-14-2005, 11:14 AM
Re: still rough 429
It's a 70's vehicle, right? It may need some higher octane; try an octane boost product, or just fill up with high test.
Old 01-14-2005, 04:52 PM
Re: still rough 429
Hey, thanks. I'll definitely try that. Thank you for all of your help.
