Old 12-01-2004, 01:12 PM
kmerian kmerian is offline
Send a message via Yahoo to kmerian
popping noise
I have a 89 Jeep Cherokee 2WD with the I-6. Lately if I try to quickly accelerate, the engine sputters and pops, very rythmic (like a machine gun) with a big dropoff in power, but if I accelerate slowly, it is fine. My guess is the fuel pump, maybe?
Old 12-02-2004, 01:19 PM
YellowXJ89 YellowXJ89 is offline
Send a message via Yahoo to YellowXJ89
Make sure your spark plugs are good shape. Then check fuel pump...
Old 02-28-2005, 08:00 PM
markhamsr markhamsr is offline
Re: popping noise
before I spent the time and money on a pump replace the fuel filter!!
you can also run a presure check on the fuel system at the fuel rail [least ways you can on a 90 - 4.0
Old 02-28-2005, 09:26 PM
tblack tblack is offline
Re: popping noise
If it had a carb I would say that's a classic sign of an accelerator pump problem within the carb. The popping noise could be a spark retardation too so another thing would be to check the timing.
Old 03-01-2005, 06:53 AM
Re: popping noise
I replaced the fuel filter and that did nothing to change the problem. A little further investigation revealed a bad fuel injector on the #2 cylinder. replaced that and fixed the problem.
Old 03-01-2005, 04:41 PM
stevelock's Avatar
stevelock stevelock is offline
Send a message via ICQ to stevelock Send a message via Yahoo to stevelock
sounds like you need to clean the injectors.
didn't see the last post oppps
1997 Jeep Grand Cherokee Laredo 4WD, 4.0L I-6 (Hers)
1996 Jeep Sport 4WD, 4.0L I-6 (mine)
