| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
1988 Olds Cutless Ciera starts, then dies and won't restart immediately
Olds Cutless Ciera, 3.8 L, The car starts, runs, often for several (40-50) miles, then dies and won't restart immediately. Replaced the fuel pump and the electronic control module, but still having the same problem. Sometimes it dies while driving, other times it drives ok, then shutoff for a short time (fuel stop), then won't restart? Appreciate your ideas. Thanks
Re: 1988 Olds Cutless Ciera starts, then dies and won't restart immediately
If you find the answer please post it. |
One of the known problems in Olds is the solenoid for the lock-up torque converter. |
I had a similiar problem,
after a year or so I had a diagnosis of a possible bad Mass Air Flow sensor (MAF) priced a new one at about 350.00, at auto zone 165.00, finally picked one up at a bone yard (Pull and Save) for 10.00. problem solved! easy to take off just three small phillip screws and unsnap the electrical. I understand you replaced your fuel pump. I need to replace mine on a 89 cutlas 3.3L need help and would appreciate your input. the tank has 2 straps.So I drain the gas unscrew the straps lower the tank and...... what next? Any help appreciated and thanx in advance...fritz678 |
Thats exactly what i had. I had problems with it idleing and running so i went to my local napa and i got one of those diagnostic keys that you atach to the metal uner the steering wheel down by the pedals. The service engine soon light will blink in a pattern. Count how many times it blinks and take that number in.. Turned out my problem was a mass airflow sensor too and i got one for 20 bucks at the junk yard
Hey Jeffe thanx a lot I appreciate your input!
fritz678 |
i had the exact same symptons, 92 buick lesabre 3.8. it was the crankcase position sensor.
