Idle Problem
When I turn my car on and let it idle it will rev up then drop down and then rev up and so on. It will only do this when it is cold out, but it doesn't always do it. What could be the problem?
Re: Idle Problem
Well you could have done a search as every 3rd thread or so is about irratic idles...but the main 3 causes are plugs, o2 sensors, or vacuum leaks. Also could be the valve on your throttle body.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
having the same problem, just noticed it yesterday.
Glad this post is on the first page, How does one decifer Exactly why its doing what its doing.. ? |
Re: Idle Problem
Change your spark plugs...costs about $6 if you know how to do it...very simple.
Clean your throttle body $3..do a search for instructions and cleaner... Pop the hood and follow all vacuum lines, listen for air leaks...you can pressure test, or you can put soapy water on all tubes and check for bubbles. bad 02 sensors typically will make your ECU throw a CEL(check engine light) they will also cause your gas mileage to go down, and for you to lose power(unfortunantly, so will all the other possible causes) Try all that...and see if anything works. All for about $9.
Re: Idle Problem
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
