Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-30-2004, 10:07 PM
FenixDown FenixDown is offline
Would it be cheaper to replace the transmission or get a new case?
I cracked my transmission case and its leaking oil now. Is it possible to just replace the case (and is it cheaper), or should I just get a whole transmission?
note: I don't have any mods on it or anything, its just my plain Jane everyday car...
Old 11-30-2004, 11:50 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
my guess would be that it would be much cheaper to just buy a used tranny and install it rather than buy a case and pay a technician to install all of your tranny parts into it.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 12-01-2004, 10:53 AM
gergwheel gergwheel is offline
Re: Would it be cheaper to replace the transmission or get a new case?
just take you case to someone that knows how to tig weld and they can weld it up and it will be as good as new, that is of course assuming it is a GIANT hole.
Old 12-03-2004, 12:56 AM
How hard is it to install a transmission? I haven't done anything major like that before. Also, how much would a transmission be for my car?
Old 12-03-2004, 04:08 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
$150 - $200 for a used non cracked case. look around ebay.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-03-2004, 10:50 AM
integralover's Avatar
integralover integralover is offline
Re: Re: Would it be cheaper to replace the transmission or get a new case?
that would definately be the best option. it will be alot less money then going to a junk yard and getting a used tranny. where is the crack loacated?
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
Old 12-03-2004, 12:16 PM
I'm not sure. I didn't see it myself, but the guy I took it to said it was cracked and tried to patch it up with something (epoxy I think) just to make it not leak as bad. It helped a little (its drivable but I gotta keep an eye on the oil level), but he said he couldn't do anything else because they don't do major transmission repairs there.
I talked to a guy at a transmission place just now, and he said that regardless of whether it can be welded or not, they would hafta take off the tranny, and since they would be doing that, I might as well try to find a used tranny and get them to put it on. The thing is, I can't find one anywhere, so I dunno. =\ Plus, it would cost $300 just for them to put it on.
This sucks...
Old 12-03-2004, 05:46 PM
you need to find out where the tranny is cracked. first. if it is in a spot that can be welded without the tranny coming off then i would definately do that. try to loo on the tranny where there will be a wet spot. and yea that sounds funny. but, look to see where it is wet and where it could be coming from. then figure from there if it can be welded. if it can then take it too some redneck shop that has a welder and give them like $40 to do it. also there is this stuff called JB Weld, if you can find the crack and think you might be able to do this yourself then i would take this JB Weld and clean off the area really good then work it into the crack and leave some around the crack to help hold it on there. and trust me on this JB Weld stuff. i cracked my engine block around the oil sending unit and used JB Weld to seal off the crack and it works. no leak. and that is with about 60psi of oil pressure behind it.
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 12-05-2004, 12:14 AM
how will I know if its in a place that can be welded? Also, how would I get all the oil out so they COULD weld it? And yeah I've got some JB Weld. I'll see if I can use some of that. Thanks for all the help so far guys!
Old 12-10-2004, 12:33 PM
Well I took it to the shop and he told me that they gotta take the tranny off before they could do anything because it was too low. So I took it to the transmission place and they're takiing it off right now and then I'm gonna take it to the welding place...
I hope this works
Old 12-10-2004, 04:52 PM
keep us informed
93 teg LS
B20B
AEM CAI
G4 High Flow Cat
Skunk2 Racing Chip
Old 12-22-2004, 02:46 AM
I got it welded about a week ago, and it seems to be holding up well. It cost $300 at the tranny shop for them to take it off $80 for the welder to weld it (it took longer than it was supposed to cuz he had to grind off the JB weld), and then another $100 at the tranny shop to replace the gasket which got torn up from the welding (from the heat I guess). Thanks for all of your help guys!
