Old 11-30-2004, 09:19 PM
Igovert500's Avatar
blue + red light magnet
interesting thread on 3si
I was just skimming 3si and thought this was an interesting thread to read:
http://www.3si.org/forum/showthread....7&page=1&pp=10
It starts discussing 4" exhausts, then other restrictions holding the 3/S platform back, compares ideas that have been used on Supras, single turbo setups, etc. It has some interesting theoretical ideas. It's 7 pages, so it takes some time, but I found had some intersting points to consider.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-30-2004, 09:49 PM
mike93vr4's Avatar
mike93vr4 mike93vr4 is offline
Re: interesting thread on 3si
how fast can we rev befor something gos wrong?
Old 11-30-2004, 09:56 PM
zax49 zax49 is offline
Send a message via MSN to zax49
i work right next a guy who owns an exhaust shop and i was asking him bout 4" exhaust because the biggest he puts on is 3" because he says when you go to big it robs hp is this right or what?
89 Toyota Supra Turbo 5-speed
Old 11-30-2004, 10:18 PM
Igovert500's Avatar
It has a negative effect on NA cars, it is BS in regards to turbo cars. This has been addressed in plenty of threads...if you want more info, do a search for "loss of backpressure" I'm sure you'll find plenty of info regarding the subject.
as far as mike's ?, I'm not sure exactly what you are asking.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-30-2004, 10:31 PM
Stealth93 Stealth93 is offline
With 4" piping the exhuats gas would lose velocity thus creating more difficulty for the engine to expell exhuast gasses. Also, with such large piping the exhuaust would cool off much more than would occur in smaller diameter tubing. The hotter the exhuast gas, the less dense it is which means that the engine will have less trouble "pushing" it out.
Old 12-01-2004, 12:34 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: interesting thread on 3si
Mike, i think what you are talking about is what damage can occur when you rev the engine up really high. There is something called "floating the valves" tha can occur b/c the lifters or springs are not designed to handle extremely high revs. however, i'm not sure what the limit is on our cars. search the 3Si forums for more info.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-01-2004, 05:50 PM
ikOnone ikOnone is offline
Re: Re: Re: interesting thread on 3si
i have heard that it is about 8000 rpm when the stock stuff begins to be a problem and valve float occurs.
1992 3000GT VR-4 TOTALED
1991 figi blue VR-4 lots to come...
1993 civic hatchback 35-40 mpg of slow reliable daily driver
Old 12-01-2004, 06:22 PM
Igovert500's Avatar
Another sweet thread...john monnin's write up on swapping in a 3.5L 6g74...and even talking about boring it out to 4.1 He actually has a detailed write-up...granted it isn't anything that'll be happening in my near future...but it's great to dream!
http://www.3si.org/forum/showthread....1&page=1&pp=10
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
