Old 11-30-2004, 08:23 PM
depress the stars depress the stars is offline
Send a message via AIM to depress the stars
94 cherokee dashboard problem
Hi,
I have a '94 Jeep Cherokee, and a year ago I installed a CD player. Ever since then, my guages don't light up, but everything does. I think I screwed up the wiring of the lighting, and I need to buy new wires for the dashboard lighting. I don't know what kind of wires i need though, does anyone know which wires would work?
Thanks a lot,
Matt
Old 12-03-2004, 02:49 AM
IdahoJeeper's Avatar
IdahoJeeper IdahoJeeper is offline
Re: 94 cherokee dashboard problem
Hi Matt!
What makes you think you need new wires, are the old ones burned or ripped out? Odds are you just lost the connection between your guage lights and the rest of your dash. Did your CD player have a connection to the dash lights? I would just go back in and check all your connection points for the CD player, then work out from there. Could be just as simple as a plug pulled out or a broken wire.
If you do find a broken or burned wire that needs repaired, any 18-20 AWG wire should be fine.
You like jazz, she likes Klingon opera, so you compromise - you listen to Klingon opera...
You like Cherokees, she likes Grand Cherokees, so you compromise - you buy a Grand Cherokee...
Old 12-03-2004, 06:31 AM
Re: Re: 94 cherokee dashboard problem
Originally Posted by IdahoJeeper
Hi Matt!
thanks a lot, that really helped. i appreciate it.
Old 12-07-2004, 05:43 PM
carjofixer carjofixer is offline
Originally Posted by depress the stars
Hi,
Thanks a lot,
Matt
Matt,
I have a horrible habit of changing radios about twice a year. The first time I did it the air control console stopped working, and some lights on the dash were out. Make sure the wires are still plugged in, sometimes when you push the radio in it will catch the harness and pull it out.
aaron
