Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-30-2004, 05:51 PM
cpcole cpcole is offline
knocking during accelleration
I do not know much about engines but I am good at fixing things....here is the problem....
My 2000 mustang knocks everytime I accellerate. The problem is worse with 87 octane gas..and goes away with 93 octane. I do not wish to keep using higher octane gas and was hopeful it was a simple problem to fix. Any ideas?
Old 11-30-2004, 07:25 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: knocking during accelleration
Check your timing it might be advanced. Did you buy the car used or brand new, GT or v6?
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 12-01-2004, 10:18 AM
SVTTOY SVTTOY is offline
you need some tune ups!! I had this problem although I was using the 91 octane!! what you would need to do is change or double check on you sparks plugs, get the OEM Ford ones and also change the Fuel filter. im hoping that would help.
good luck
Old 12-01-2004, 02:45 PM
Re: Re: knocking during accelleration
It is a V6 not GT..bought used.....checking timing may be advanced for me...i will look into it though, but like i said...i do not know much about cars.
thanks!
Old 12-01-2004, 02:46 PM
good luck
i will try...hope it works...i will let you know!
thanks!
