Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-30-2004, 05:40 PM
j.b.z j.b.z is offline
Unhappy Help! My civic is hesitating while driving
If you can help,
I just changed my spark plugs and wires thinking this would solve my problem but it didn't. My car still has hesitation when I am driving. Also, the check engine light just came on when I was going up a hill. The car like sputs and hesitates to hit gear right, it seems like it is misfiring. The plugs I put in are bosch platinum 4's and bosch wires. Please if anybody has any suggestions help me out.
Old 11-30-2004, 06:22 PM
DreamRacer DreamRacer is offline
i had the same problem, use ngk plugs
Old 11-30-2004, 06:45 PM
fakehatch fakehatch is offline
I had the same problem, turns out my iat sensor was acting up, but then decided to fix itself(HONDA!) Haven't had any problems since. My advice would be to get your check engine light checked first and then go from there. check your air filter also. good luck.
Old 12-01-2004, 11:01 AM
exman98 exman98 is offline
Re: Help! My civic is hesitating while driving
check your timing?
Old 12-01-2004, 02:12 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
Did you check the cel code? Do you have any mods on the car? Did you check your distributor? Unscrew the cap and check to see your rotor and contacts inside aren't rusted. If they are, those parts are relatively cheap to replace.. Otherwise it could mean anything from a bad fuel pump, injectors, to a blown headgasket or piston ring(s).
Old 12-01-2004, 08:19 PM
Re: Re: Help! My civic is hesitating while driving
Originally Posted by exman98
check your timing?
how do i check my timing on the car?
Old 12-02-2004, 02:37 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
give us the code.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-02-2004, 09:21 PM
you would probably have to take it somewhere to get your timing checked
Old 12-05-2004, 11:12 PM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
or buy a timing gun at the local car store
Old 12-06-2004, 02:55 AM
AF - Advisor
GIVE US THE CODE!!!!!!!!!!! Jump the wire!
My money is on the CEL.
