Old 11-30-2004, 03:28 PM
91metallicblue 91metallicblue is offline
Question green sensor on intake?
Hi all,
I went and had a diagnostic check done, and the mechanic
said the green colored sensor located on the intake 'may'
need to be replaced. It's located under the air intake housing
and next to the idle speed control valve. My car has that
infamous idle-surging problemo.
Any responses appreciated.
Have a good one!
Old 11-30-2004, 08:26 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: green sensor on intake?
its the temp sensor that measures the temp of the water flowing through throttle body. if it doesn't get right reading it can cycle the idle up and down
Old 12-01-2004, 06:07 AM
SeanMurphy's Avatar
SeanMurphy SeanMurphy is offline
If it's the sensor on the back right (if facing the car) of were the air filter goes, its your intake air temp sensor. If this sensor is broken it will make your computer think that the air temp is always -44`C, making it run rich all the time. I had a problem where the wire broke off the connector on mine, causing the ecu to throw a code on my 98 metro. I soldered the wires back together and put some epoxy on it to stiffen up the connector and it's worked fine ever since.
Now if I could just get my timing problem sorted, we'd be all systems go.
02 Chevrolet Tracker 4WD
Old 12-02-2004, 01:47 AM
Thanks for the help, guys. I don't see any broken wires nor interchangeable parts. If it had to be changed, that looks like a beast of a job. The Hayes manual doesn't cover this
Ah well, if I can't fix this surging problem, I'll just put a piece of electrical tape on the hole in the air filter housing that leads to the EGR valve - no more surging...ever
