Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 11-30-2004, 02:03 PM
cletus023 cletus023 is offline
Piston Rings
So how difficult is it to change a piston ring yourself and what kind of tools do you need? also if a cylinder i low on compression, could there be other problems besides just a bad ring? The car gets about half the mpg it used to. Thanks.
Old 11-30-2004, 05:11 PM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
Re: Piston Rings
Could be a bent valve as well.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 12-01-2004, 11:35 PM
jefboyardee jefboyardee is offline
Re: Re: Piston Rings
Don’t forget the obvious... a not-fully-inserted or cracked spark plug.
Old 12-02-2004, 12:33 AM
Re: Re: Re: Piston Rings
Oops, sorry, my bad. That is, assuming you’re pulling the plug to check
the compression.
Old 12-02-2004, 06:58 AM
i changed all the plugs and the condition didnt change so i dont think its that. also, is there a way to get the car from running so rich or is it just a result of the compression being off? Thanks.
Old 12-02-2004, 11:23 PM
Re: Piston Rings
Others here will be much more qualified to answer than I, and I’ve
already stuck my foot in my mouth... but I’d guess that it sounds
plausible. The fuel injector’s computer relies on precise information and a
compression fault may throw that data askew.
Old 12-03-2004, 06:29 AM
Re: Piston Rings
any hints are better than no hints, i appreciate the help
