Old 11-30-2004, 01:14 PM
dagoEF's Avatar
dagoEF dagoEF is offline
b16 Throttle body and alternator questions
Does anyone know if I could use a 91 integra throttle body on a 1st gen B16? I compared the two and they seem to have the same diameter, but I'm not sure if I would need the vtec one. I don't like the fact that my b16 one had to have the tps replaced and screwed in. the b18 one has the factory set tps and I would rather use that one. Also what tb gasket would I use for that? 91 teg b18 non-obd or 94 del sol b16 obd-1?
Also would a 90dx d15b2 alternator work on the 1st gen b16? I heard as long as they are non-obd it would, just want to find out for sure before I try. Which car would I need one for if I went for a higher aperage one 91 teg?
Old 12-01-2004, 09:11 PM
dagoEF's Avatar
Re: b16 Throttle body and alternator questions
*bump* anyone???
Old 12-02-2004, 01:33 AM
Hybrid1990crx's Avatar
im pretty sure that integra TB should work. And whats wrong with the tps? The one on my b16 was broken and I replaced it with the one from the d16a6 and it works fine. And what do you mean "screwed in"?
And about the alternator, im pretty sure it wont work because the wiring harness is diffrent. But im not 100% sure.
Old 12-02-2004, 02:14 AM
dagoEF's Avatar
By "screwed in" I mean that when I had it replaced He tapped the TB and used screws to hold in the TPS, no gasket eitherbetween the two, and hand calibrated with a multimeter. I've been having idling issues with it and I was just trying to narrow things down. I heard that sometimes the TPS can be off slightly and not throw a code, maybe I'm wrong. I'd rather have the factory set one so I don't hve to worry bout that.
On the alternator, no one knows what the equivalent us model of a jdm b16a alternator would be?
Old 12-02-2004, 02:58 AM
why did he have to tap? Wasnt it already treaded? What TPS did you use?
Old 12-02-2004, 08:58 AM
dagoEF's Avatar
The stock TPS is riveted in, My friend helped me with the swap and he did it, I'm not sure which TPS he used.
Old 12-02-2004, 01:59 PM
Are you sure it was riveted in? The one on my a6 LOOKED like it was riveted in, but it just had funky screws that I had to cut sluts into so I could use a flathead screwdriver to get them out.
Old 12-02-2004, 03:38 PM
dagoEF's Avatar
I'm not positive, My buddy did it before I got to his house, I remember him telling me it was riveted . I'm gonna try to get a gasket from autozone and compare it to the TB and the pic in the manual, I'll see what happens.
Old 12-02-2004, 04:48 PM
Mojoe Mojoe is offline
90 Integra for the alternator....not sure if the D will work.
58mm diameter for either tb, I would "think" either gasket would work. Check the mating surfaces and look for differences.
What kind of idle issues...high?low?erratic? http://www.hondaswap.com/forums/inde...howtopic=29790
Old 12-02-2004, 06:38 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
The throttle bodies are pretty much the same. It will work. As for the alternator, As long as the mounting brackets are the same, it should work also. Make sure the pulley is the same as your crank pulley, meaning that it takes the same belt.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-02-2004, 06:40 PM
dagoEF's Avatar
Thanks for the info on the alternator guys.
The idle is prob is kinda hard to explain, Since I got the swap it's always had a very slight misfire. For a while it would stall if the car was facing down a steep slope, and I thought it was the fuel pump (which I haven't eliminated yet). Fixed a couple exhaust leaks (cheap ass welds), and I felt a little difference. It would misfire sometimes, and I found out my header is bent, one pipe more than the other (ordered new one not arrived). Distributor? (plan on replacing anyway). Last week I was in the drive-thru and I noticed everytime the fan came on the lights would dim and the car would choke. So now I think it might be a combination of possibly the header and the alternator.
Old 12-02-2004, 07:19 PM
I doubt its your header unless its pretty much smashed closed... one of my pipes is dented in halfway and the car runs fine.
Looks like your on the right track with changing the alternator for your electrical, might want to have it checked (Autozone/similar)out before buying new.
Before my distributor crapped out it felt like a hard miss. I pulled the cap off and it was loaded with red dust and with the distributor out I couldn't spin the shaft easily, bearing was seizing up.
Old 12-02-2004, 09:10 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
the TB will fit, the alternator Will not.
Tried bolth.
Kun
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 12-02-2004, 10:36 PM
dagoEF's Avatar
Thanks again guys, I'm goin to Acura next week to pick up a 91 teg tb gasket to see it it'll work only 6 bucks so what the hell, picked up a "newer" used b16 alternator today for $20, so I'll get that tested before I put it in, hopefully that works until I can afford a better one.
Old 12-03-2004, 12:32 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
i bought a 90-91 integra alternator for my b16. works perfectly.
also running a TB from a 90-91 integra as well. also works perfectly.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
